 Post subject: Spindles???????????
PostPosted: Sun Dec 14, 2008 12:56 pm
Anybody know what this spindle is from, I got this beam with my choptop project from a guy in Clarksville Tn and then sold the beam to Kevin Fondren and he is looking for bearings
 Post subject: Re: Spindles???????????
PostPosted: Sun Dec 14, 2008 6:00 pm
That almost looks lik a balljoint spindle on a king front end. Neat.
PostPosted: Sun Dec 14, 2008 6:05 pm
Not sure what it is, not stock for sure. Can he measure (mic) the two bearing fits? I might be able to figure it out from that.
PostPosted: Sun Dec 14, 2008 6:56 pm
Just talked to Kevin to get measurements and he said he went to the parts store and did some cross checking and found that a 67 bus inner and KP beetle outer works,,,,,,still don't know for sure if its been custom built ,,or what?
PostPosted: Sun Dec 14, 2008 7:51 pm
Wanna sell them??
PostPosted: Sun Dec 14, 2008 8:11 pm
He told me he barrell rolled at Fultondale this weekend . I sold him the beam about a year ago . Now he needs it.,,,He was lucky,,said he got knocked out..no helmet.
PostPosted: Sun Dec 14, 2008 8:21 pm
Where at at fultondale :?:
PostPosted: Mon Dec 15, 2008 3:39 am
Marty,Those are "Wrightplace" spindles They were built in the 70-80's before "Combos" I have a set of them I took of my single seater that Was raced in the 80's and I still beat it up badly and no problems from them yet! Tell him to call McKenzie's or Kartec or Saco GermanAuto
If he can wait a few days I can get him the numbers off my brg's,,,let me know
p.s. I was also told years ago the were modified 356 Porsche spindles but I have never compared them,he might try them brg sizes
PostPosted: Mon Dec 15, 2008 9:45 am
I have two sets of them. One on my buggy and a spare set that someone f'd up by cutting part of the steering arm off of the spindle. I was told that they are porsche 356B spindles. They are the same as beetle spindles except for the diameter of the actual spindle. I think you can even use stock k/l pin drums. I know they are tough because I've sheared the link pins a few times but have not damaged the spindles.
PostPosted: Mon Dec 15, 2008 7:35 pm
Rockrockets I flipped off of a rock high wall where coridoor x is passing through. The wall was about 60 ft high I made it to the top and was spinning going backwards and before I could stuff the clutch and hit the brakes it hooked on th epassenger side and started flipping. I will find out tommorow about the 356 bearings fitting I had to order them. I will post tommorow with the news thanks guys for all your help.
