| Longer Wheel Bolts? http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=4482 |
| Author: | Bad Influence [ Sun Aug 17, 2008 5:58 pm ] |
| Post subject: | Longer Wheel Bolts? |
I'm needing to put wheel spacers on my front wheels to be able to clear my brake caliper. I'm needing a wheel bolt that is about 20mm longer. Can I buy those from the auto parts store or is it something I'm gonna have to make? Thanks |
| Author: | Kyle [ Sun Aug 17, 2008 10:20 pm ] |
| Post subject: | Re: Longer Wheel Bolts? |
you should be able to buy them local. usually a Carquest is the best bet because they have actual wheel nuts. they can match the thread and sell you a longer bolt. be warned my front lugs from carquest were 6.00 a piece ONLY place I could get them. Kyle |
| Author: | purplerail [ Sun Aug 17, 2008 11:16 pm ] |
20mm longer? what kind of set up do you have? pics? |
| Author: | mudd mutt [ Mon Aug 18, 2008 2:00 am ] |
Kyle wrote: you should be able to buy them local. usually a Carquest is the best bet because they have actual wheel nuts. they can match the thread and sell you a longer bolt. be warned my front lugs from carquest were 6.00 a piece ONLY place I could get them. Kyle I got cans full of them goof ball,,,,why would you pay 60 for them |
| Author: | Bad Influence [ Mon Aug 18, 2008 9:16 am ] |
purplerail wrote: 20mm longer? what kind of set up do you have? pics? I'll take some pics tonight. |
| Author: | Kyle [ Mon Aug 18, 2008 9:47 am ] |
mudd mutt wrote: I got cans full of them goof ball,,,,why would you pay 60 for them I needed them right away hahaha and I only bought 3 because some how I lost 3 at wellsville hahaha |
| Author: | instigator [ Mon Aug 18, 2008 8:54 pm ] |
put some 1/2 wheel studs in it and be done with the bolts. |
| Author: | Bad Influence [ Mon Aug 18, 2008 9:29 pm ] |
instigator wrote: put some 1/2 wheel studs in it and be done with the bolts. Do you just get some wheel studs and press into the rotor? Bolts suck!!! They are a pain to line up. |
| Author: | instigator [ Mon Aug 18, 2008 9:39 pm ] |
take the hub to the auto parts and find some that will fit.or you can order them from jegs 1/2 20 3" long set of 5 for 15.00 youll still need lug nuts too hope this helps |
| Author: | kybuggy1 [ Mon Aug 18, 2008 11:22 pm ] |
Instigator is right. You will like the studs . It is a pain enough to line up a wheel for the bolts, much less throw the spacers in there too. You will be cussin w/o studs!! The alum. wheels are cool, but the non-reverse offset, with the spacers added on top of that will make it a handful in the woods, unless you got a power rack or big ol' S10 box or something. Puts alot of stress on steering components.... and your arms, gives the tires more leverage to jerk around with. Really does make a big difference. Stock Beetle wheels work real nice with stock steering box. Larry |
