It is currently Tue May 05, 2026 3:57 am
 Post subject: Longer Wheel Bolts?
PostPosted: Sun Aug 17, 2008 5:58 pm
I'm needing to put wheel spacers on my front wheels to be able to clear my brake caliper. I'm needing a wheel bolt that is about 20mm longer. Can I buy those from the auto parts store or is it something I'm gonna have to make?
Thanks
Bryan
 Post subject: Re: Longer Wheel Bolts?
PostPosted: Sun Aug 17, 2008 10:20 pm
you should be able to buy them local. usually a Carquest is the best bet because they have actual wheel nuts. they can match the thread and sell you a longer bolt. be warned my front lugs from carquest were 6.00 a piece ONLY place I could get them.
Kyle
"Lets go get stupid"
PostPosted: Sun Aug 17, 2008 11:16 pm
20mm longer? what kind of set up do you have? pics?
PostPosted: Mon Aug 18, 2008 2:00 am
Kyle
I got cans full of them goof ball,,,,why would you pay 60 for them :roll:
PostPosted: Mon Aug 18, 2008 9:16 am
I'll take some pics tonight.
Bryan
PostPosted: Mon Aug 18, 2008 9:47 am
I needed them right away hahaha and I only bought 3 because some how I lost 3 at wellsville hahaha
PostPosted: Mon Aug 18, 2008 8:03 pm
With 20mm spacer wheel doesn't rub on brake caliper. This is a bad angle. The caliper does miss the bolts.
Wheel is flat with no offset and bolts are actually in path of brake caliper
Caliper sticks out past rotor face. Normally wouldn't be problem with offset wheels.Image
Spacer in place.
If there is a better way to do this please give me a shout.
Thanks
Bryan
PostPosted: Mon Aug 18, 2008 8:54 pm
put some 1/2 wheel studs in it and be done with the bolts.
PostPosted: Mon Aug 18, 2008 9:29 pm
Do you just get some wheel studs and press into the rotor? Bolts suck!!! They are a pain to line up.
Bryan
PostPosted: Mon Aug 18, 2008 9:39 pm
take the hub to the auto parts and find some that will fit.or you can order them from jegs 1/2 20 3" long set of 5 for 15.00 youll still need lug nuts too hope this helps
PostPosted: Mon Aug 18, 2008 11:22 pm
Instigator is right. You will like the studs . It is a pain enough to line up a wheel for the bolts, much less throw the spacers in there too. You will be cussin w/o studs!!
The alum. wheels are cool, but the non-reverse offset, with the spacers added on top of that will make it a handful in the woods, unless you got a power rack or big ol' S10 box or something. Puts alot of stress on steering components.... and your arms, gives the tires more leverage to jerk around with. Really does make a big difference.
Stock Beetle wheels work real nice with stock steering box.
cron
