axel question???
http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=4083
Author:  lilD [ Sun Jun 22, 2008 2:22 am ]
Post subject:  axel question???
i have a 3 rib with bus cv's on the tranny and car cv's by the wheel.i just got some complete bus axels the other day.will they fit right on??so that way,i'd have bus to bus cv's and bus axels.or will i have to just use the cv's???please let me know if this will work or not.thanx.
Author:  sdbillyg [ Sun Jun 22, 2008 4:26 am ]
Post subject:  Re: axel question???
you have to use different stub axles for bus cv's
Author:  Firebug [ Sun Jun 22, 2008 6:36 am ]
Or have the machinist to redrill your bug stubs to accept bus cv's. Or use thing stubs.,,,better yet go to 930 stuff. 8)
Author:  A. Cole [ Sun Jun 22, 2008 3:54 pm ]
I assume you have stock trailing arms, so the bus axle will not work. As the others said, to run the bus cv on the outside you will need to have a new or drilled stub axle to except bus cv's. Stock irs axle is 16 1/4 " and bus are 18 3/4".
