| how much rear ground clearance do you have http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=3632 |
| Author: | plumberbill [ Wed Apr 16, 2008 11:16 am ] |
| Post subject: | how much rear ground clearance do you have |
i have 14" to lowest point of my skid plate. just wondering what others have. |
| Author: | Firebug [ Wed Apr 16, 2008 6:01 pm ] |
| Post subject: | |
PB, I am right there with you with the 31's . 15" with the boggers at 3psi . Measured at a comfortable pressure in the bags. I can run the bags up stiffer and gain a couple inches when necessary. |
| Author: | sdbillyg [ Wed Apr 16, 2008 6:23 pm ] |
| Post subject: | |
with 33" boggers I have 18" under skidpan |
| Author: | frankenbuggy06 [ Wed Apr 16, 2008 6:53 pm ] |
| Post subject: | |
31" tires. 19" ground clearnce |
| Author: | plumberbill [ Wed Apr 16, 2008 10:55 pm ] |
| Post subject: | |
Firebug wrote: PB, I am right there with you with the 31's . 15" with the boggers at 3psi . Measured at a comfortable pressure in the bags. I can run the bags up stiffer and gain a couple inches when necessary.
i could gain a few by cranking up the torsion adjusters or adding nitrogen to fox airshox but that leaves me with just about no droop in the suspension. not sure how critical that would be in the trails. |
| Author: | Odyknuck [ Thu Apr 17, 2008 9:55 am ] |
| Post subject: | |
You will have the best ride and control with a minimum of 30% droop. The droop allows the tires to follow the terrain and keep them on the ground for traction. Any less you start to sacrifice the reasons you went to mid or long travel supension to begin with. |
| Author: | Roy [ Thu Apr 17, 2008 10:31 am ] |
| Post subject: | |
Well put Steve. I would sacrifice ground clearance anyday to have a suspension that works well. I have mine set up with almost 40% in droop. |
| Author: | Kyle [ Thu Apr 17, 2008 11:37 am ] |
| Post subject: | |
33 boggers....19 inches 31 firestones....15 inches 31 denmans....16 inches 29 goodyears....13 inches those are our garages 4 numbers. |
| Author: | toradi [ Thu Apr 17, 2008 12:01 pm ] |
| Post subject: | |
With Firestone 31"x12.5L-15 got 13 " to bottom of skid plate. 14" in the front with 700x15 |
| Author: | RailHomie [ Thu Apr 17, 2008 2:18 pm ] |
| Post subject: | |
This is a good thread. Gives a good idea of initial adjustment for your buggy. |
| Author: | kybuggy1 [ Thu Apr 17, 2008 2:46 pm ] |
| Post subject: | |
frankenbuggy06 wrote: 31" tires. 19" ground clearnce
Thats pretty phenomenal. You chaindrive? No belly bars? I got clearanced 930's, 31's,and 2x3's, and only got 15" if I'm cranked to where I'm sittin on the stops and riding like a road wagon. Engine is kicked up a little, too, to gain clearance. Setup for good ride and transfer and I got about 13" clearance sittin in the garage, spring plates about 1/4" off the stops with 3/4" notches in them. Ride it all day and it squats more than that. Starting to take a set though, gonna have to crank her up soon. Larry |
| Author: | volksdude2007 [ Thu Apr 17, 2008 8:25 pm ] |
| Post subject: | |
i have 31 on my buggy and just adjusted recently and lost a few but was sitting close to 18 i think now i am at 16 |
| Author: | buggy66 [ Thu Apr 17, 2008 9:40 pm ] |
| Post subject: | |
My wife said that I have at least 12inches. |
| Author: | m.ralston [ Thu Apr 17, 2008 9:46 pm ] |
| Post subject: | |
If i had 12" to go with my good looks,i wouldn't be maried! |
| Author: | plumberbill [ Fri Apr 18, 2008 8:01 am ] |
| Post subject: | |
m.ralston wrote: If i had 12" to go with my good looks,i wouldn't be maried!
you would be a porn star |
| Author: | 69buggytyme [ Mon Apr 28, 2008 9:18 pm ] |
| Post subject: | |
what the heck is droop? |
| Author: | MadMike [ Mon Apr 28, 2008 9:34 pm ] |
| Post subject: | |
It's how far into the suspension your car sits. Where my front end sits at ride height, if I were to jack it up, I would have to jack it up 4" before the tires leave the ground. I have about 30-35% droop. |
| Author: | nickschlemer [ Tue Apr 29, 2008 1:40 am ] |
| Post subject: | |
I have more than enough 18 up front and 22 in back.. |
| Author: | Roy [ Tue Apr 29, 2008 1:29 pm ] |
| Post subject: | |
Chaindrive Rail wrote: I have 0" to 38" on 44"s.
Air bags and chains are good! Curt "show off" |
| Author: | ncbuggy [ Wed Apr 30, 2008 10:58 pm ] |
| Post subject: | |
What's up with you being good. I liked it better the other way. |
