It is currently Mon May 04, 2026 7:39 am
 Post subject: wheel travel with 3x3s
PostPosted: Mon Dec 17, 2007 3:34 pm
I am doing a swingaxle to 3x3 conversion and want to know what kind of wheel travel i can get out of the set up? I am using 930 cvs and after market axles with stock torsion bars. What would be the advantage of going coil over in the rear? thanks Kendel
PostPosted: Mon Dec 17, 2007 7:36 pm
You should be able to get 14" of travel if you set it up correctly. Stock torsion bars will not work with the 3x3's. They will last about two weeks.
