It is currently Mon May 04, 2026 12:07 pm
 Post subject: GM steering box??
PostPosted: Sun Dec 16, 2007 7:00 pm
Does anybody have pics of mounts for gm box?? I need ideas on mounts. Thanks in advance.
Steve
 Post subject: gm box
PostPosted: Sun Dec 16, 2007 10:21 pm
This is a pic of the one I am using [right side drive from mail truck] it may give you an idea. Hope it helps.Image
PostPosted: Sun Dec 16, 2007 10:27 pm
Good looking fabbing..I like the bus beams...careful about bumpsteer with that pitman that far back. 8)
PostPosted: Mon Dec 17, 2007 10:29 pm
Accually the pitman arm is 180 out.
That pic was taken before setting links.
Going to hex rods and heim joints.have
stock ties now for mock up.
The lower steer arms have been cut off and
welded on the upper knuckle of spindle
in exact position to keep steering geo-
metry same.
PostPosted: Mon Dec 17, 2007 10:57 pm
I get it,,,pleas show the pics when you finish 8)
PostPosted: Wed Dec 26, 2007 10:59 pm
Anybody else got any ideas? I like the mount but rightside drive boxes are not a dime a dozen but s-10 ones are!
PostPosted: Wed Dec 26, 2007 11:36 pm
use which ever side you get your hands on ---the mount just gives you ideas.
PostPosted: Sun Dec 30, 2007 11:28 am
I`ve used S10 for about 4 years now and have had no problems,I picked mine up at junkyard for $50.I will get some pics later today for ya.
aaron
PostPosted: Sun Dec 30, 2007 4:29 pm
How did you have it mounted in your old car?
