Wheel base
http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=2101
Page 1 of 2
Author:  D. Marks [ Sun Dec 02, 2007 8:30 pm ]
Post subject:  Wheel base
I am kicking around a couple ideas to help my buggy climb. They both include a longer wheel base. Right now my wb is 93". Pretty short I think. Can you tell me what the wb is on some of your buggies? And what you like or dislike about it. I am trying to figure out how long is to long.
Thanks
Dean
Author:  Odyknuck [ Sun Dec 02, 2007 9:04 pm ]
Personally I would not go over 100" WB if your going to trail ride. Even at 100" tight trails can be tricky to manuver thru. Power steering would be a great help on longer wheel bases so I would consider that if you go longer. I know thats what Im doing on my new Buggy and its only 98".
Author:  Stevo [ Sun Dec 02, 2007 9:20 pm ]
put a SUBARU in it.
Author:  Firebug [ Sun Dec 02, 2007 9:22 pm ]
yea a cd suby :wink:,,,,,oops,,,,,stole a thread,,,,, uh my wb is 102
Author:  Stevo [ Sun Dec 02, 2007 9:31 pm ]
OH YA! mines 100'' stalker. the old car was 103, sorry Dean
Author:  ky-bc [ Sun Dec 02, 2007 10:10 pm ]
103"......... modified "beeline, pro 95" frame
Author:  frankenbuggy06 [ Sun Dec 02, 2007 10:42 pm ]
dont know what my frame is but i legenthened it 15" went from 87" to 102" and most of the time all 4's are planted on climbs
Author:  sharpshooter [ Sun Dec 02, 2007 10:56 pm ]
most of the bama buggys are 105 thats with 3x3s,my 4 seater is 112, but as long as I pay attention on trails I have know problems,I do like the point of sitting closer to the front ,you have a better view
Author:  rockrockets1 [ Sun Dec 02, 2007 11:12 pm ]
120 IN CUSTOM CHAIN DRIVE
ROCKROCKET!
IF YOU AN'T LIVING ON THE EDGE YOUR TAKING UP TOO MUCH SPACE!!!!!!!!!
Author:  The Wild Kids [ Mon Dec 03, 2007 1:36 am ]
106 here cutting brakes are a must on tight trails with a little bit of speed and no worries.
The Wild Kids
Author:  Roy [ Mon Dec 03, 2007 5:40 am ]
Mine is 100"
Author:  DVS1 [ Mon Dec 03, 2007 12:37 pm ]
Mine is about 101"
Author:  MadMike [ Mon Dec 03, 2007 9:34 pm ]
98" now, needs to be 102"
Author:  redrail1915 [ Mon Dec 03, 2007 9:53 pm ]
mine is 102"
Author:  plumberbill [ Mon Dec 03, 2007 10:06 pm ]
105" with 3x3 rear and 21/2" extended up front
Author:  Kyle Martin [ Tue Dec 04, 2007 10:11 am ]
Mine is 100 inches dean, same frame as hillaholic.
Author:  m.ralston [ Wed Dec 05, 2007 8:35 am ]
Dean mine is 100-102. i havn't checked it since i put ext. arms on the front. But length is not as important as most think. Its all about suspention,balance,and low center of gravity. I know alot of short buggies that climb good.Most guys at D and K are under 100.Look at Smitys.
Author:  bruce 1 [ Wed Dec 05, 2007 10:20 am ]
Where do you measure the wheel base from? From center of wheel to center of wheel, or total length of frame?
Author:  Odyknuck [ Wed Dec 05, 2007 10:24 am ]
Wheel centers
Author:  wildwillie [ Wed Dec 05, 2007 11:43 am ]
AROND HEAR 99-101 IS IDEAI FOR TRAIL RIDEING AND HILL CLIMBING MINE WAS 97" AND COULD NOT KEEP IT OFF THE ROOF I MOVED IT TO 100 1/2 IT HELPED ALOT..
Author:  Blake [ Wed Dec 05, 2007 1:53 pm ]
101-102, I think.
Author:  bruce 1 [ Wed Dec 05, 2007 2:23 pm ]
single seater 100" , two seater 98"
Author:  GAMNTRAIL [ Wed Dec 05, 2007 9:58 pm ]
I'm at 90" . I've had the same thoughts as you, My front end is usually aimed at the sky on some of the steeper hills & I have an 8000lb winch infront. I'm not sure what to do.
Bruce
Author:  Baddvw [ Mon Dec 10, 2007 12:22 pm ]
Mine is 101 1/2" long.
Author:  RaceBugg1098 [ Tue Dec 11, 2007 10:32 am ]
damn, Gamntrail, thats a heavy winch!!! you must have put heavy springs in your beam!! ha,ha,ha.
