| empi supper shifter http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=17454 |
| Author: | holeman [ Fri Nov 07, 2014 12:34 pm ] |
| Post subject: | empi supper shifter |
how do ya adjust a supper shifter.i can get it in reverse with out pushing the button down.so when i down shift from 3rd it trys to go into reverse?any ideas? |
| Author: | holeman [ Fri Nov 07, 2014 6:53 pm ] |
| Post subject: | Re: empi supper shifter |
come on guys should i just throw it in the trash bin and get me another shifter or what? |
| Author: | brandon1776 [ Fri Nov 07, 2014 7:25 pm ] |
I have the same problem but I cant figure it out. Im gonna buy a different one this winter. Posted using the WoodsBuggy Mobile App |
| Author: | MadMike [ Fri Nov 07, 2014 7:30 pm ] |
holeman wrote: come on guys should i just throw it in the trash bin and get me another shifter or what? Sorry man but you do know that EMPI stands for Every Mistake Passes Inspection? Not a clue on the shifter. |
| Author: | bige70chevy [ Fri Nov 07, 2014 10:06 pm ] |
try the adjuster on the shaft...the one under shifter box, not on trans |
| Author: | reno2165 [ Fri Nov 07, 2014 10:46 pm ] |
Is that the box style shifter with the button on the side?? Jamar makes the same kind with the button on the box and its the best shifter ive had... put the trans in reverse and then put the shifter in reverse and lock everything down, always done it that way and it shifts perfect |
| Author: | holeman [ Fri Nov 07, 2014 11:24 pm ] |
thanks reno ill try that |
| Author: | BAJABUGNUT [ Sun Nov 09, 2014 5:59 pm ] |
See the problem you guys have is you bought the Chinese knock of the Chinese knock off The EMPI Supper Shifter, What you should have bought was the Chinese knock off EMPI Super Shifter... You have been scammed... |
