PostPosted: Sat Dec 21, 2013 1:48 pm
stock type 1 rear irs on woods buggy. Would u recommend fox air or emulsions on rear. this is also a street legal buggy.
PostPosted: Sat Dec 21, 2013 3:58 pm
The Fox Air Shock is a suspension shock. That means it holds up weight just like a coil spring or a torsion bar.
An emulsion shock is just that, a shock.
Two different worlds.
What are you trying to do or solve?
My first reply would be anything more than a good 'over the counter' shock is overkill with stock arms.
PostPosted: Sat Dec 21, 2013 4:09 pm
stock width and length trailing arms. just trying not to get beat up by the end of the day on trail rides. want a smooth as I can get ride while offroading without huge expense. I will still be using torsion bars as well
PostPosted: Sat Dec 21, 2013 11:48 pm
Well if your going to use the torsion bars then use emulsion shocks as the air shocks will be an expensive over kill. A set of adjustable Rancho 9000 series will work fine for your application.
