It is currently Mon May 04, 2026 1:05 pm
PostPosted: Sun Dec 08, 2013 3:25 am
Ok so I am looking to buy a new frame and am not sure what to get. I like the truck style frames but am not sure if that is the best way to go or not. I am looking for something with more room than the frame that I have now ,it will need to be a 2 or 4 seater. Also I want it to climb well, the one I have now climbs great.
I have a 2180 motor that runs very strong, dry sump system , 6al box, 6 rib trans, 3x3 rear trailing arms and extended front trailing arms also four racerunner air shocks. I am looking for a full welded frame, I will ad extra supports and bracing I Also would like to put a custom torsion front and rear witch would eliminate the torsion bars.
This is the frame I have now anyone know what it is I'm not sure.
PostPosted: Sun Dec 08, 2013 4:05 am
Are you going to replace your current frame or build a new buggy?
What do you mean by "More Room"... Do you want more head room? Do you want more arm room? Did you want more room to store stuff?
PostPosted: Sun Dec 08, 2013 8:22 am
Stalker with 3" cage rise and custom torsion options.
PostPosted: Sun Dec 08, 2013 2:32 pm
Looks like a berrien to me. mine is small as well.have to hang my head out the side to look up a hill before i climb. I agree with ody.the stalkers are nice.that or a beeline.
PostPosted: Sun Dec 08, 2013 2:39 pm
yes I am replacing my existing frame. and i would like more room in all the places you stated. I would like to have enough room to to put suspension seats in. also the reason that i was looking at the truck style frame is for camping trips and things like that with the family then i could take a large cooler, tents, sleeping bags and so on.
the main thing i want room for are the suspension seats and a good place to put the oil tank for the dry sump witch is mounted in the front of my buggy now and i have oil lines ran over a 7 foot run to the tank and i want have the tank mounted behind the seats and maybe room for a room for some small speakers.
PostPosted: Sun Dec 08, 2013 5:59 pm
the stalker is a good one for what your wanting
PostPosted: Mon May 19, 2014 11:43 am
Stalker
