It is currently Sun May 03, 2026 7:00 pm
 Post subject: 2x3 vs 3x3
PostPosted: Wed Feb 19, 2014 1:57 pm
I'm currently looking for extended trailing arms for my new project. What are the pros and cons of 2x3s and 3x3s? I'm not wanting to go crazy on them just yet. I also am wondering about axles for both of them. Any help would be great.
 Post subject: Re: 2x3 vs 3x3
PostPosted: Wed Feb 19, 2014 6:32 pm
Pro's
2x3's use bus axles.
3x3's = more suspension travel.
Con's
3x3 axles cost more.
3x3's make the buggy 2 inches wider.
Sent from my SM-N900P using Tapatalk
PostPosted: Wed Feb 19, 2014 8:21 pm
I thought 2x3 was 2 wider and 3 back
3x3 was 3 wider 3 Back :?
Which would make wheel travel the same .... ?
PostPosted: Wed Feb 19, 2014 10:50 pm
I was thinking the same as u on this one.
PostPosted: Wed Feb 19, 2014 10:52 pm
Huey wrote:
Pro's
Con's
How much abuse will the bus axle take? I've got a stock 1600dp and a 3 rib. I'm probably gonna run a 33" mud tire not sure which one yet.
PostPosted: Wed Feb 19, 2014 11:22 pm
They will take a lot. I run them with a 2165 stoker with dual delorttos 3 rib just went from 36 to 35 inch tires and flip it half the time I ride. I been running the same pair for 10+ years and no problems with them
PostPosted: Wed Feb 19, 2014 11:53 pm
My thoughts are longer axles give you more travel. Think of it in extremes. If the axle was 20 feet long versus a axle 1 foot long with the same cv joint angle. The 3x3 axles are longer than the 2x3 axles. The cv joint is the limiting factor.
PostPosted: Thu Feb 20, 2014 1:27 am
I understand what your saying.
PostPosted: Thu Feb 20, 2014 1:28 am
What size arms are u running?
PostPosted: Thu Feb 20, 2014 8:47 am
I think they are 2 x3 it has stock bus axles
PostPosted: Thu Feb 20, 2014 9:36 am
I didn't realize u could run that big of a tire w 2x3s. I know there a lot more to it with wheel offset and brakes but just didn't realize u could go so big. That's got me leaning more towards 2x3s now. Lol
PostPosted: Thu Feb 20, 2014 9:50 am
Well I have a single spring plate off a swingaxle cut down to fit my 2x3 so it doesn't have the nub sticking out like what's on the IRS spring plate
PostPosted: Thu Feb 20, 2014 1:53 pm
I've heard u can cut the nub off and run a swing axle putter plate. I have a dual plate irs set up now on both of my buggies.
PostPosted: Thu Feb 20, 2014 3:25 pm
I'm not sure about cutting the nub off but If I'm not wrong with 2x3 or 3x3s you can run up to 36 inch tires a lot of people around here run 36 buckshots
PostPosted: Thu Feb 20, 2014 6:32 pm
I run 36 inch buckshots on my 2 seater with 2x3s and have about an inch between the tire and the stob.
PostPosted: Thu Feb 20, 2014 8:17 pm
Thanks for the info guys. I look forward to catching up with some of you on the trails once I'm up and going.
PostPosted: Thu Feb 20, 2014 9:10 pm
I run 3x2 arms with 36" buckshots.. beetle torsion and not alot of offset on the wheels with no problems
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
