It is currently Sun May 03, 2026 7:16 am
 Post subject: front end ideas!!!
PostPosted: Sun Sep 01, 2013 7:46 pm
trying to get some ideas on a front end its set up with a
balljoint now and don't want to cut my frame up to switch to
kingpin if any of you guys got some ideas or have
tried something to get some height out of it let me know thanks!!
 Post subject: Re: front end ideas!!!
PostPosted: Sun Sep 01, 2013 8:37 pm
The eaziest thing do is put another balljoint front end on it and be Dunn with or you will cut and rewelding on it good luck
PostPosted: Sun Sep 01, 2013 8:56 pm
How bout some spindles that are raised??
PostPosted: Sun Sep 01, 2013 8:58 pm
I can't find them anywhere!
Make em:)
PostPosted: Tue Sep 17, 2013 2:03 am
You can buy them new on dans performance parts
PostPosted: Mon Oct 07, 2013 2:13 pm
anybody have a suggestion for softening the front end? can you just take a few springs out? it has new shocks and ball joints, just super stiff! doesn't allow any flex when hitting a hill off camber, it just raises the other wheel as well causing it to jerk the steering wheel out of my hand? thanks
PostPosted: Mon Oct 07, 2013 2:53 pm
Are the ball joints in the right way? If they're in wrong they'll bind up and not move. Did you put new bushings in? What are the shocks for?
Yes you can remove springs. If you do remove same amount from top as you to from bottom.
