 Post subject: bagging opnions?
PostPosted: Wed Jun 12, 2013 10:03 pm
looking at maybe putting bags on wanting to know any does and dont and best bang for your buck and any pics of any ones setup would be apprciated to also am running 2.2 subaru didnt know if the weight would matter much thx for any input
*subiepower*
 Post subject: Re: bagging opnions?
PostPosted: Wed Jun 12, 2013 11:04 pm
also what is the best do u have a pump or just a fill valve and with it at ride height what is the way to get most comfort out of it judging by what else is on here looks like the #3800 from airbag it work the best so thats what i would probaly go with
*subiepower*
PostPosted: Wed Jun 12, 2013 11:24 pm
I could refer you to a topic on how NOT to do it. :roll:
PostPosted: Wed Jun 12, 2013 11:27 pm
yeah what mike said...if you search airbags on this site you find what your looking for...
PostPosted: Wed Jun 12, 2013 11:30 pm
Image bags from airbaggit.com #3800 bags...5000lbs...i run 50-60 psi in mine depending on passenger and where im riding,air them up at home and theyre good to go...,rancho shocks,long travel torsion eliminator
PostPosted: Wed Jun 12, 2013 11:55 pm
In addition, do whatever you need to do like longer wider arms, 930 cv's and axles FIRST. Setting up air bags with parts your not going to be using is a waste of time. Treat the air bag like a shock, don't over extend the bag, do not pinch the bag when fully compressed, the top of the bag wants to be 90 deg from the arm at full compression. Find the spot on the arms that matches the stroke of the bag minus the "safety" That's pretty much where the lower bag mount needs to be.
PostPosted: Thu Jun 13, 2013 8:21 pm
ya i see his but wasnt so sure on the mounting i seen that funco project had a swivel on the bag what is the advantage of that . so what angle do i want my axles siting at with bag compressed or should i do it with 35 psi and set axles at 25 degrees or what ever the 930 bottom out at ?
*subiepower*
