| Ball Joint Beam (Wheel Stop Bracket) http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=14840 |
| Author: | myrddin [ Fri Feb 08, 2013 10:21 am ] |
| Post subject: | Ball Joint Beam (Wheel Stop Bracket) |
Is it common to cut the wheel stop off the ball joint beam? I noticed that the beam I have will turn till the tire rubs the frame (tire to frame is the stop)... just wondering... guess I will live with it as is.. Plan is to rebuild the front, like I did the rear next winter anyway. My bracket is cut off I guess (its not there) and the pitman arm is cut also where the part comes out that should hit the adjustment bolt. thanks guys... ![]()
| Author: | rip-it [ Fri Feb 08, 2013 10:56 am ] |
| Post subject: | Re: Ball Joint Beam (Wheel Stop Bracket) |
You need to make some stops or you will tear up your steering box. |
| Author: | Red Barron [ Fri Feb 08, 2013 11:40 am ] |
Never ran a stop on my cars with stock steering boxes and don't run one now with my rack. My dad welded a bolt on each spindle to limit on his four seater when I was a kid. |
| Author: | myrddin [ Fri Feb 08, 2013 11:50 am ] |
OK I get the idea... I will take a look and see if I can get something in there to stop it... worst case It will all come out in the fall anyway... Red, the bolts you brought up would be where? Past owner cut all the wheel stop stuff off... so its clean... I mostly didn't like the idea of the tire being able to hit the frame... but if its how a lot of folks do it... then I will let it ride for the summer... I did look and there is nothing, I would need to make something if this is a problem I guess. |
| Author: | hpfreak [ Fri Feb 08, 2013 12:32 pm ] |
if you like the paint to stay on your frame you might want to fix it. mine is the same way and it took the paint off the first time i turned it. let me know what you do so i can copy it |
| Author: | myrddin [ Fri Feb 08, 2013 12:41 pm ] |
lol... yeah, I may try something out... in my case everything is cut off... so hard to modify what's not there |
| Author: | 2800passat [ Fri Feb 08, 2013 12:50 pm ] |
Everything works ok on my a/c buggy. It shifts ,it stops it runs but the SECO center steer rack with an old Rancho shock for a dampner is the best working component on the whole buggy. It is a great pleasure to steer comfortly and hit washouts without the steering wheel getting knocked out of my hands.Atleast put a steering shock on it. |
| Author: | Red Barron [ Fri Feb 08, 2013 8:43 pm ] |
I will taken a photo and draw on it in sketch up tomorrow. |
| Author: | Red Barron [ Fri Feb 08, 2013 10:44 pm ] |
Guys I apologize my mind was thinking king and link pin not ball joint. I looked at the a book I have called Baja Bugs and Buggies book and they don't cover the ball joint much. If i had one in front of me I am sue I could figure it out. So sorry about my some-timers disease. |
| Author: | jesse [ Sat Feb 09, 2013 4:46 pm ] |
I fixed my dads from doing this real simple way I will take a pic when im at the shop in a little and post it tonight |
| Author: | myrddin [ Sat Feb 09, 2013 7:02 pm ] |
thnx man... will be looking out for it... |
| Author: | jesse [ Sat Feb 09, 2013 9:39 pm ] |
man i forgot lol but will deff get it tomorrow what i did was weld a small peice of flat steel off the bottom arm so when you turn to a point it hits it |
