 Post subject: KP bushing question
PostPosted: Mon Dec 31, 2012 10:20 pm
ok can someone tell me what the diffrence between this is what is MICARTA
URETHANE AXLE BEAM BUSHING KIT, INNER & OUTER FOR KING/LINK PIN w/ BEARINGS, SET OF 4
URETHANE AXLE BEAM BUSHING KIT, INNER & OUTER FOR KING/LINK PIN w/ MICARTA BUSHINGS, SET OF 4
 Post subject: Re: KP bushing question
PostPosted: Mon Dec 31, 2012 10:51 pm
McKensie in California sells the yellow urethane bushings that don't sleek. Call them and tell them what you have and they will ship them. They also carry the Pinot bolt bushings in yellow for the rear. Guaranteed to be squeak free
PostPosted: Tue Jan 01, 2013 12:42 am
im needing the ones for the front end and woundering the diffrence between the 2 i listed i dont know what MICARTA is
PostPosted: Tue Jan 01, 2013 12:55 am
Micarta is a fiber type bushing, for the lack of a better term. The way I read it is VW made two types of "bearings" for the link pin beam. One is the standard timken needle bearing they are calling bearing set and the other is the micarta they are calling bushing set. I have never seen a micarta bushing in a beam only bearings, which means nothing. I have no idea what the difference would be between the two beams other than Inside Diameter of the tubes.
PostPosted: Tue Jan 01, 2013 1:13 am
ok i believe thats my problem i have a KP with the bearings removed and i got a set of bushings and they have Micarta on the pack and wont fit so i must need the others
PostPosted: Sat Jan 05, 2013 8:54 pm
Get the blue delrin from kartek an be done with it.
