It is currently Sun May 03, 2026 6:54 am
 Post subject: Apple trees 2x3 arms
PostPosted: Sat Mar 27, 2010 10:33 am
I seen somebody post a pic of these arms not to long ago and they were cracked around the bearing housing.
Can you post that pic again i cant seem to find it?? and a pic of how you fixed it. I called apple trees and he wants to see a pic of it so that he can stiffin it up.
 Post subject: Re: Apple trees 2x3 arms
PostPosted: Sat Mar 27, 2010 3:50 pm
Here is a broke one posted on thesamba.
http://www.thesamba.com/vw/forum/viewtopic.php?t=380500&highlight=trailing+arm
PostPosted: Sat Mar 27, 2010 9:59 pm
Thanks man maybe they can fix this shit.
PostPosted: Mon Oct 01, 2012 8:56 pm
Bored looking at old posts. Am I the only one that sees why his arm cracked? Look at the angle he has the shocks mounted at, he is literally trying to rip the trailing arm off with them. :roll:
PostPosted: Mon Oct 01, 2012 9:11 pm
the same shocks came on my monaco go cart. doesnt look like a whole lot of penetration on the weld either
PostPosted: Mon Oct 01, 2012 10:55 pm
Someone needs to show this guy how to set up a rear suspension. A shock mounted with one mounting tab at that. The failure shown has a lot to do with the items listed in posts above. Just like the latest rage stuff. Always stiffen the area under and around shock mounts especially if your not going to run a limit strap.
