PostPosted: Wed Jan 25, 2012 6:06 pm
Is it posible to take out the torshion bar in a ball joint front end so i can put could over shocks on?
PostPosted: Wed Jan 25, 2012 6:08 pm
It is possible to do, just add through bolts. I would question why?
PostPosted: Wed Jan 25, 2012 7:12 pm
Because i bought my buggy with the front end already welded so the front end sits at max height. This makes the ride really rough. I basically want to convert to coil overs so i have a softer ride without having to buy an entire new front end.
PostPosted: Wed Jan 25, 2012 7:19 pm
Have you considered extending the trailing arms to take advantage of the coil-overs? If they aren't already extended.
PostPosted: Tue Jan 31, 2012 12:33 am
Yep take your grub screws out all the way around. The torsions slide out. The hole left by the torsions is more than large enough for some threaded rod.
PostPosted: Wed Feb 08, 2012 9:09 pm
Can i get extended ball joint arms?
PostPosted: Wed Feb 08, 2012 9:22 pm
They can be made, just a matter of setting up a good jig.
PostPosted: Sun Feb 19, 2012 5:09 pm
The holes left by the torsion seem a bit too big. is there something im missing?
PostPosted: Sun Feb 19, 2012 11:32 pm
i think most folks weld a plate over the end and then drill a hole in the center for the thru rod or either use a couple of thick washers on each side, but im sure somebody else will chime in
PostPosted: Tue Mar 13, 2012 7:53 pm
You can see what i ended up doing at this link.
http://www.woodsbuggy.com/index.php?opt ... 23&t=13044
PostPosted: Tue Mar 20, 2012 9:26 am
I think some weld a washer to the arm that has the right size hole. Or you can up the diameter of the rod your using.
PostPosted: Mon Mar 26, 2012 8:10 pm
Ya i made one. you can see it on the link.
PostPosted: Mon Mar 26, 2012 10:27 pm
Sorry if this seems highjacking ,
But has any one used the through rod on just one torsion, say either the top or bottom. I mean most every buggy I have seen with a BJ front have both torsions in, That front end was ment to carry a full size sedan, not a light weight buggy.
What's everybody's thought?
PostPosted: Tue Mar 27, 2012 10:00 am
If your front end is to stiff you can take out 1 or 2 springs but if you do make sure you take the same amount top and bottom.
PostPosted: Tue Mar 27, 2012 12:28 pm
Thanks hillaholic, I will start there.
