| end load or center load rack???? http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=12999 |
| Author: | rip-it [ Thu Jan 19, 2012 12:28 pm ] |
| Post subject: | end load or center load rack???? |
I have done some research and there are many threads on r&p steering. But I still have some questions; do I want a center load rack or an end load rack? |
| Author: | Maddog [ Thu Jan 19, 2012 12:33 pm ] |
| Post subject: | Re: end load or center load rack???? |
Center load is stronger and will have less bump steer problem. |
| Author: | Odyknuck [ Thu Jan 19, 2012 1:11 pm ] |
General rule for best results is as follows: Center load - Trailing arm style supension (covers most Woodsbuggys) End Load - "A" Arm style supension (used mostly for Sandrails) |
| Author: | rip-it [ Thu Jan 19, 2012 2:07 pm ] |
Looked it up on Alldata and sure enough this style is end load. Damn it!!! |
| Author: | tw9294 [ Thu Jan 19, 2012 8:29 pm ] |
An end load rack out of a 99 grand am is EXACTLY what i have. If i had any more travel i would need a center load but as is works fine. I want longer arms and more travel up front so i will probably switch to center load but i'm still going to use a gm rack. I have'nt been a bit sorry for the swap and if your happy with stock arms and travel you should be fine with the 99 r&p.
| Author: | jayrod [ Sun Jan 22, 2012 2:48 pm ] |
Havta agree, I have the 99 grand am rack works great. |
| Author: | manther [ Tue Jan 31, 2012 1:48 pm ] |
tw9294 wrote: An end load rack out of a 99 grand am is EXACTLY what i have. If i had any more travel i would need a center load but as is works fine. I want longer arms and more travel up front so i will probably switch to center load but i'm still going to use a gm rack. I have'nt been a bit sorry for the swap and if your happy with stock arms and travel you should be fine with the 99 r&p. ![]() Hows bumpsteer? (on street and dirt). Ive got kinda a dual sport. |
