 Post subject: Pitman Arm Confusion
PostPosted: Tue Sep 25, 2007 8:05 pm
I am looking to buy a new chrome Pitman arm for the buggy that I'm building. 1970 balljoint front end with 1970 steering gearbox. Do I need the large shaft & small tie rod holes, the small shaft & small tie rod holes, or the small shaft & large tie rod holes?????
PostPosted: Tue Sep 25, 2007 11:15 pm
I think the one with the large holes is for use with the ford/international tie rod ends but Im not sure.
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
PostPosted: Wed Sep 26, 2007 10:54 am
The spline that slides over the steering box shaft has been the same since about 1961 or so.
The tie rods holes were smaller in the king/link pin and early ball joint era.
The later ball joint had a larger tie rod hole.
PostPosted: Wed Sep 26, 2007 6:07 pm
Thanks guys.......Looks like I need to go with the large tie rod end hole & large shaft........it measures .950
Aaron
