It is currently Sun May 03, 2026 9:59 am
PostPosted: Thu Oct 13, 2011 9:21 am
Are are some sperior to others?
I'm going to have to import a pair from the US and there appears to be many different vendors with wildly varying prices..
PostPosted: Thu Oct 13, 2011 10:23 am
I use stub axles from http://www.precisionalloy.com/ They start with stock stub axles cut the type 1 CV bell off and weld a 930 CV bell in it's place. The original German axles are made out of really good material, better than what you'll find in any aftermarket stub axle. They are done right and at a reasonable price.
PostPosted: Thu Oct 13, 2011 10:54 am
Thanks Mike, I value your opinion. As they don't have a price on thier site, and as it'll cost me £££ to call them from the UK do you know the approximate cost?
PostPosted: Thu Oct 13, 2011 11:36 am
shoot them an email tbf@pacifier.com
PostPosted: Fri Oct 14, 2011 2:50 am
Todd emailed me last night..
PostPosted: Fri Oct 14, 2011 6:30 pm
What do they run????? $$$$$ My guess is they are a pretty penny.
PostPosted: Mon Oct 17, 2011 8:37 pm
my buddy help me take a car stub axle and grind the bell down flat we got a broke bus joint and offset the holes from the car tac welded in place and drill new holes and treaded them and when you put them in and install the joint put nuts on back of bolts they work pretty good when your out riding and break a joint you can use car or bus to get back home i have run mine in the woods for 7 years with no problem
PostPosted: Mon Oct 17, 2011 10:23 pm
I will tell you to stay away from EMPI as they are junk. I have bent one and snapped two. I am sure the weight and HP of my car did not help however just sayin!
