| front arm Q http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=12462 |
Page 1 of 2 |
| Author: | jesse [ Mon Oct 17, 2011 8:55 pm ] |
| Post subject: | front arm Q |
i have a 6 inch wider beam with 3 inch drop spindles its also a baljoint beam with saco rack it snatches the wheel horribly would this be the drop spindles causing it and if so what size arms should i go with to get my height back where it is now |
| Author: | Firebug [ Mon Oct 17, 2011 9:10 pm ] |
| Post subject: | Re: front arm Q |
put a charlynn on it and forget it |
| Author: | jesse [ Mon Oct 17, 2011 9:13 pm ] |
whats that lol |
| Author: | Firebug [ Mon Oct 17, 2011 9:25 pm ] |
jesse wrote: whats that lol charlynn torque generator,,,came on fork lifts,,,put it inline in your steering shaft and run a power steering pump and lines and you can steer with one finger and no feedback..here is a deal on ebay: http://www.ebay.com/itm/190588036630?ss ... 1438.l2649 |
| Author: | jesse [ Mon Oct 17, 2011 9:28 pm ] |
what all is involved in hooking that up |
| Author: | giveitagallon [ Mon Oct 17, 2011 9:30 pm ] |
Lmao , Ive been watching that item and ill bid at the last min so game on ! That funny you threw that up ! Small world |
| Author: | giveitagallon [ Mon Oct 17, 2011 9:35 pm ] |
jesse wrote: what all is involved in hooking that up Just like bug said , put it in line with your steering shaft and put a power steering pump on your motor and run lines to it and then a beer in one hand and steer with the other ! |
| Author: | Firebug [ Mon Oct 17, 2011 9:44 pm ] |
Here is another,,,copy the number and paste from time to time and you will get lucky,,,,or find a salvage yard with fork lifts,,, http://www.ebay.com/itm/120780402820?ss ... 1438.l2649 you will need to modify the pump a little,,,borer a bigger hole mainly |
| Author: | passat2800 [ Mon Oct 17, 2011 10:05 pm ] |
If you dont get a Charlynn do you have enough caster, next, way too tall tires. 3rd too much bump steer,and do you have a dead steering dampner?Back to the raised spindles , you raised the spindles , but did you position them about an inch to the rear like a stock position.Caster means like the wheel on a shopping cart. Just trying to help.If you have the spindle mounted ahead ANY of the ball joints, 2 gorillas can't even steer it. |
| Author: | jesse [ Mon Oct 17, 2011 10:14 pm ] |
i did not make them they was on it when i got it but they could be off and no i have no dampener ima mount a rancho one and see if that helps if not ima look into it more |
| Author: | passat2800 [ Mon Oct 17, 2011 10:20 pm ] |
Consider this. Me and Austin, really really REALLY love our A arms. Mine is pwr steering, his has a cadillac rack and pinion but no power running to it. Turns extremly sharp and perfect.$15 at Pull a part .After people drop a cady motor there is one 1/2" bolt left and it is loose from the car.It is the same GM rack from most any other front wheel drive car except it is 2 " wider.When you get in the gas the frame will lift over ruts stumps midgets etc. |
| Author: | passat2800 [ Mon Oct 17, 2011 10:26 pm ] |
Get a shock that pushes and pulls with the same resistance of coarse.You may buy a Rancho dampner , get it out of the box and realize you have no room in your buggy to mount it..So do your homework 1st.Not trying to be a know it all, it's just that I have made all of these mistakes b4. |
| Author: | jesse [ Mon Oct 17, 2011 10:46 pm ] |
oh all advice is appreciated dd |
| Author: | mudd mutt [ Tue Oct 18, 2011 2:21 am ] |
If your frt wheels are reversed (turned around backwards with all offset to outside)turn them back around that will fix 90% of it been there done it and proved it with friends buggys 50-50 wheels will work good |
| Author: | RaceBugg1098 [ Tue Oct 18, 2011 12:28 pm ] |
I put my money on it being the rack! put a charlynne on it and you'll never look back! |
| Author: | hillaholic [ Tue Oct 18, 2011 1:18 pm ] |
Do you have any pictures of how and where the rack is mounted. I had the same problem. The rack was in the wrong location causing almost 3" of tow out when the suspension compessed. I would suggest checking the tow at ride height then at full compression and see what the change is. |
| Author: | giveitagallon [ Tue Oct 18, 2011 1:31 pm ] |
RaceBugg1098 wrote: I put my money on it being the rack! put a charlynne on it and you'll never look back! Is it me or did that have a little ryme to it ? Aka rapper racebug |
| Author: | tw9294 [ Tue Oct 18, 2011 9:18 pm ] |
hillaholic wrote: Do you have any pictures of how and where the rack is mounted. I had the same problem. The rack was in the wrong location causing almost 3" of tow out when the suspension compessed. I would suggest checking the tow at ride height then at full compression and see what the change is. I agree with this thinking. you have way too much bumpsteer. play with mounting location of rack untill your toe change is the least it can be throughout the suspenion travel. |
| Author: | nitro_mudder [ Tue Oct 18, 2011 10:32 pm ] |
The closer you can get the racks piviot points to the beam the less bump steer. Simple geomatry if you take your time and think about it. if the rod ends are in line with the beam (front trailing arm pivot) then the length will not change as it cycles through the motion. Must also be centered height wise with the ends at the spindles for this to work. |
| Author: | jesse [ Wed Oct 19, 2011 10:21 pm ] |
i will post pics of it tomorrow and see what yall think from what you can see |
| Author: | jesse [ Sat Oct 22, 2011 9:49 pm ] |
here is some picks of my setup is all mounted correctly ? ![]() ![]() ![]() and the drop spindle
| Author: | nitro_mudder [ Sun Oct 23, 2011 1:11 am ] |
Hard to be certain from the pics but I think its the spindles. Could you take a top view of them??? Looks like the spud is forward of the piviot, instead of behind and acting like a caster like the guys mentioned befor. Also looks like the center of your tire is a ways out from the balljoints/piviot points. both would cause a lot of feedback from the tires to the steering wheel if I am correct. I am sure some of these guys can either confirm this or correct me if I am wrong. |
| Author: | jesse [ Sun Oct 23, 2011 1:26 am ] |
thanks for the feedback and i will get a pic from the top tomorrow and post it i have some stock spindles i may throw on their if thats the case and just deal with the less ground clearance im tired of breaking my wrist and fingers lol |
| Author: | nitro_mudder [ Sun Oct 23, 2011 1:34 am ] |
jesse wrote: thanks for the feedback and i will get a pic from the top tomorrow and post it i have some stock spindles i may throw on their if thats the case and just deal with the less ground clearance im tired of breaking my wrist and fingers lol Well I agree with Jayrod from another post. I had problems with that when I went to a manual chevy steering box. But when I went to power steering it went away. Any way you go, I strongly recomend the power steering. I can drive down most trails with my knee as long as I dont need to clutch. Great for lighting a smoke, but you need "The Vest", lmao. |
| Author: | stroker2332 [ Sun Oct 23, 2011 6:48 am ] |
you need to put stock vw wheels back on, the one's you have don't have correct back spacing |
