 Post subject: raise spindles
PostPosted: Mon Oct 10, 2011 2:05 pm
What r raised spindles exactly do or do I want the drop spindles
 Post subject: Re: raise spindles
PostPosted: Mon Oct 10, 2011 2:39 pm
http://www.jimscustomvw.com/3raspforbajo.html you want these
PostPosted: Mon Oct 10, 2011 6:32 pm
It is not a raised spindle it is a drop because you are droping the stub on the spindle which gives you more lift !
But I would modify your gas pedal first from what your buddy's told me ! You ride with me I'm calling ya driving miss daisy or lazy lol 8)
PostPosted: Mon Oct 10, 2011 7:20 pm
Are these the same http://www.appletreeauto.com/product.ph ... 661&page=1
PostPosted: Mon Oct 10, 2011 8:29 pm
Are those same as the ones u posted diamonddave
PostPosted: Mon Oct 10, 2011 11:21 pm
Southern Buggys / WB Sponsor
Go king pin, custom long arm, dropped spud. That is the perfect setup....I can fab it up for you if you would like (small fee)
PostPosted: Tue Oct 11, 2011 12:06 am
yeh but man those look like a used set or something! or get a bigger gas pedal or go king pin :shock:
PostPosted: Tue Oct 11, 2011 4:28 pm
Before you decide to run the drop spindles consider 4" longer trailing arms. The drop spindles are really hard on the King and Link pin bushings and/or bearings, been there done that!
PostPosted: Tue Oct 11, 2011 5:15 pm
I was thinking of doing 2x3 trailing arms with some air bags and then lifting the front some how
PostPosted: Tue Oct 11, 2011 5:31 pm
so what about drop spindles on a ball joint front end? cause thats what i got and was also considering them?
PostPosted: Tue Oct 11, 2011 5:39 pm
they work great, ive run them for years.. I wish every thing went as smooth as a ball joint front end 8)
PostPosted: Wed Oct 12, 2011 5:23 pm
What size drop spindles do u guy's think I should get to go with 2x3 trailing arms and air bags
PostPosted: Thu Oct 13, 2011 8:48 am
Ok lets clear some things up here. We were talking about front supension correct?
I am assumming the 2 x 3 arms and air bags are for the rear supension correct?
For the front I am talking about using 4" longer arms in lieu of the drop spindles.
PostPosted: Thu Oct 13, 2011 10:29 am
Unless your getting them custom made there is only ONE size, that is a 3" drop.
I would suggest, before asking more questions, do a but load of reading. All of the information you are seeking is here, all you need to do is LOOK for it.
PostPosted: Fri Oct 14, 2011 11:57 pm
dont use them they throw everything out of wack and wear it all lout faster its worth just going with longer front arms
PostPosted: Sat Oct 15, 2011 11:59 pm
x2
PostPosted: Mon Oct 17, 2011 8:15 pm
you can try a taller set of tires on front i run a tall 3 rib tractor tire on my i have not put my drop spindle on this frontend yet
PostPosted: Mon Oct 17, 2011 8:23 pm
If you use a king pin front end and want 4 lug spindles you can machine off the king pin spindles smooth,,,then take a set of ball joint spindle and machine them smooth while leaving some material. Go ahead and drop them an inch or so, maybe 2 inches,,, this will gain height,,stronger spindles,,easier disc conversion,,,a tiny bit of width,,,but also some compramise in handling,,,gain a little ,,lose a little. Oh and go ahead and get longer arms too,,,,,, good luck
knew I must have missed this;
