It is currently Sun May 03, 2026 8:24 am
PostPosted: Sat Oct 01, 2011 11:24 am
im sure this been discussed million times..but i been debating on what to do..i already have a little set of air bags for the rear.. i trail ride and lil hill climb..im gonna be runnin torsion eliminators/3x3 trailing arms/31in tires/bus joints..so should i just fab up the air bags and run emulsion shocks?, or save up n get coilovers?,or try the air shock?,..coilovers are prolly the best way but also most expensive..and if i did run air bags are the fox emulsions any better than rancho,bilstien?..and should i just get emulsion shocks for front king pin?..is the air shock be better for stock king pin front end?...im just trying get good comfortable ride lol..thanks for any help
PostPosted: Sat Oct 01, 2011 11:39 am
Air bags In my opinion , cheap and easy to adjust ! Things to keep in mind how you set them up and the bigger the bag the better ! Airbagit.com #3800 is what alot of us runs or ran and if I did not have coilovers I would have the bags again !
PostPosted: Sat Oct 01, 2011 7:19 pm
I like the saw-way air shocks over fox . They hold up the buggy with less air pressure.
