It is currently Sun May 03, 2026 7:57 pm
 Post subject: front arms
PostPosted: Sat Sep 10, 2011 9:04 pm
so does anyone make longer arms for link pin front ends or do yoy u have to fab these yourself ?
 Post subject: Re: front arms
PostPosted: Sat Sep 10, 2011 9:25 pm
Are you asking for longer arms for stock spindle carriers?
PostPosted: Sat Sep 10, 2011 9:39 pm
yes , ihave a stock link pin but would like longer arms. my thinking is it will give more travel and shorten my wheel base some. im at 111 inch now too long to navigate some times but too late to start over. i could use another couple of inches ground clearence in the front also.
PostPosted: Sat Sep 10, 2011 9:49 pm
trailing arms
PostPosted: Sun Sep 11, 2011 12:35 am
There are a couple of guys that have cut up stock arms and made them longer with different degrees of success. Most of us have migrated away from stock components, I haven't had any stock link/king pin parts in several years. If you have any welding-fabrication skills, extending a set of arms, with the right guidance is a straight forward job. Building a GOOD jig is key.
As far as shortening down a 111 inch chassis, 2 1/2" longer arms isn't going to do a bunch to help. Any more than 2 1/2", your opining up a whole new set of problems.
