How do I tell what Year ?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=12148
Author:  ROCKITV8 [ Tue Aug 09, 2011 6:56 pm ]
Post subject:  How do I tell what Year ?
Just bought a buggy with drum brakes and want to change to a disc W/ E brake kit. It is titled a 1973, but how do I know that the rear half IS a 73 IRS ? I know it has IRS....just so you know that. :) Can you send me some pics or tell me how to tell the different years? Thanks
Author:  MickeyMouse [ Tue Aug 09, 2011 8:52 pm ]
Post subject:  Re: How do I tell what Year ?
I might be wrong but I do not think it matters. Anything between a 68 and a 73 should work. You will see different years from the vendors but I think it only changes the length of the e-brake cable.
Why are you using an e-brake? I only ask because you are very limited on your brake options if you want an e-brake. Most of the e-brake options will only give you a single piston caliper and a single piston caliper is not strong enough to stop a 33 inch tire going down a decent hill or hold the buggy on a hill if you need to back down.
If you must have an e-brake to be street legal, I would see if a Line Lock would work. Then you can buy a good set of disc brakes with 4 pistons. I really like Jamar but most people use Willwood.
Good Luck.
Author:  bigDsmith [ Tue Aug 09, 2011 9:32 pm ]
A '73 tranny mount has 3 horizontal bolts to the trans and 2 vertical to the frame. I believe you are right MickyMouse about the length which shouldn't matter for a rail. It looks like this:
Image :lol:
Author:  ROCKITV8 [ Thu Aug 11, 2011 4:35 pm ]
Good info! Thanks, Where is a good place to get 4 piston brakes?
Author:  MickeyMouse [ Thu Aug 11, 2011 9:07 pm ]
Southern Buggies is one of the site sponsors and is always a great place to start. Tim will not steer you wrong. He knows everything about buggies and will always help out.
Author:  ROCKITV8 [ Fri Aug 12, 2011 4:32 pm ]
http://i164.photobucket.com/albums/u36/ ... mount1.jpg
This is the tranny mount I have. Year??
Author:  bigDsmith [ Fri Aug 12, 2011 7:51 pm ]
Post subject:  yRe: How do I tell what Year ?
I don't know for sure. Looks like it has been modified and welded to the frame which appears to be square thus changes the mounting mounts. I just installed my e brakes on my 73 torsion. The cables are too long which made me use a cable shortening kit.
Author:  woogiebugger1 [ Fri Aug 12, 2011 8:34 pm ]
Bigd correct, rockitv8, yours is pre-73.
Author:  ROCKITV8 [ Fri Aug 12, 2011 10:01 pm ]
Ok, so my next question is, what do I buy a rear brake kit for (year?) also what is a good kit to buy that is more than a one piston caliper without breaking the bank :roll: I want a good set up for trail and need E brake for the street. I am going to go down to Jim's Custom VW in Columbiana in the morning and try to get some info also. Thanks
Author:  Andrew_Ha [ Fri Aug 12, 2011 10:15 pm ]
Jim is a good Guy wish he would become a sponsor here
Author:  tw9294 [ Sat Aug 13, 2011 9:49 am ]
As far as linelock for e-brake. Ohio law says it has to be a MECHANICALY operated brake so any hydraulic operation of e-brake won't pass an inspection. The single piston caliper econo brake kits with e-bk would'nt stop a go cart safely :lol: :evil: :lol: I had those on my car and with both feet pushing the brake pedal they would not lock up a tire. My car is road driven and i have no e-bk. I put 4 piston wilwood calipers on my car and it is one of the best changes i ever made. Worth every dime :!: :!: :D
Author:  ROCKITV8 [ Sun Aug 14, 2011 11:09 am ]
I never made it to Jim's yesterday. What Wilwood kit did you buy? Do I just tell them I need a kit for a Pre 73? also does yours have an E brake? Should I go with 4 lug or 5 ?
Author:  MickeyMouse [ Sun Aug 14, 2011 8:36 pm ]
If the law requires a mechanical brake, you might need to use the single piston. However, I would just leave your drum brakes rather than going to a single piston caliper.
Maybe you can wait to get it inspected and then change the brakes.
Author:  tw9294 [ Sun Aug 14, 2011 9:10 pm ]
I did'nt buy a wilwood kit. I started out with the econo brake kit with e-bk.(first pic) These sucked so i bought wilwood calipers from summit. They offer them for different rotor thicknesses. I'm using the same rotors that came with the original kit i bought but made my brackets to bolt wilwood calipers.(second pic)
