| Torsion caps? http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=11885 |
| Author: | kernal1984 [ Fri Jun 17, 2011 12:41 pm ] |
| Post subject: | Torsion caps? |
This is what i got can i put the flat ones on ive seen? Im going to 33s in the rear and i think there gonna rub the stock ones
| Author: | ehale [ Fri Jun 17, 2011 1:35 pm ] |
| Post subject: | Re: Torsion caps? |
get you a set of 2x3 trailing arms they benefit more than just running a larger tire |
| Author: | MickeyMouse [ Fri Jun 17, 2011 1:37 pm ] |
Yes.. But you will need to change your torsion bars, spring plates, bushings and caps.. By the time you are through, it might be cheaper to just buy 2X3 arms. If you do go to new spring plates, you can sell the ones you have.. A lot of people like the double plates. |
| Author: | kernal1984 [ Fri Jun 17, 2011 2:30 pm ] |
Ive got some 2x3 arms they need to be straightend and boxed can i just get bus axles and use my CVs or is the spline different? |
| Author: | ehale [ Fri Jun 17, 2011 6:27 pm ] |
kernal1984 wrote: Ive got some 2x3 arms they need to be straightend and boxed can i just get bus axles and use my CVs or is the spline different? splines are the same |
