It is currently Mon May 04, 2026 7:44 pm
 Post subject: torsion bar removal?
PostPosted: Fri Apr 08, 2011 6:35 pm
I am an uber noob to this lol!!! I am finally breaking down and using my green buggy for parts. I have never taken torsion bars out or installed them. I dont want to break anything or hurt myself so I figured I would ask the experts! Picture and/or videos would help the most! I imagine some one has a link to a video on youtube.
Thanks again guys and hope to be there memorial day!,
Dieseltechy360 (Cameron)
Without failure there is no success. We must be allowed to fall so we learn a better way to get up.
 Post subject: Re: torsion bar removal?
PostPosted: Fri Apr 08, 2011 6:46 pm
Go to the search topic and search it,there has been several post on this topic with pics.spring plates are loaded with pressure so watch when you knock them off but other than that you should be to just fine.hit problem somebody will help.chad :mrgreen:
PostPosted: Fri Apr 08, 2011 6:49 pm
I appreciate the help!!!
PostPosted: Fri Apr 08, 2011 9:46 pm
I looked it up in the search bar but had no luck.
PostPosted: Fri Apr 08, 2011 11:44 pm
The trick is really getting them on.. Getting them off just takes a good pry bar..
Do you have an IRS or a swing Axle?
PostPosted: Sat Apr 09, 2011 9:15 pm
IRS is what I have.
PostPosted: Sat Apr 09, 2011 9:50 pm
Remove your swing arm first.then take the torsion cover off.then what I do is take a tie rod knocker drive it in between the spring plate and housing and I tap the end of the torsion bar with a hammer.when the spring plate come off the stops it got quite a bit of pressure and will kick down.then just pull the torsion bar out.pretty much it.any more questions just ask .Chad :mrgreen:
PostPosted: Sat Apr 16, 2011 6:15 pm
this may help its not a buggy but its a irs and will give you a good idea just if you wanna raise yours do the opposite of the guy in the video and theirs 4 parts to the vid so that's all them vid 3 has some good math thats teaches you how to set it
http://www.youtube.com/user/cugir#p/u/16/AMxBolHOJR4
http://www.youtube.com/user/cugir#p/u/15/Gmh5V1sKlTM
http://www.youtube.com/user/cugir#p/u/14/WA5jYrkwewg
http://www.youtube.com/user/cugir#p/u/13/41V5g9s_Lbw
PostPosted: Mon Apr 18, 2011 1:14 am
Go to, mydune-buggy . Chech the tech pages, there is a really good link for this.
