 Post subject: suspension seat mounts
PostPosted: Thu Feb 10, 2011 9:01 pm
I have a pretty solid idea how im going to mount my new seats, but does anyone have any pictures of their mounts? Curious to see what everyone else was doing.
PostPosted: Thu Feb 10, 2011 9:16 pm
on mine im useing the cross bars for the front of the seat i bought some tabs from la that are rounded at the tube end and im bolting angle iron to the back tabs on the seat then the angle iron will be bolted to the floor . ill take some pics tomorrow for ya of the tabs !
PostPosted: Thu Feb 10, 2011 9:22 pm
My suspension seats have tabs for bolting horizontally to metal such as angle iron along the sides.
If you cut the rearmost tabs so they will just slide back and hook on bolts welded to your angle iron mounts, then you can use only 2 bolts or pins to hold the front tabs to angle iron mount.
This isn't very clear, but I can remove the seat by just pulling the front 2 pins and the seat slides right out.
