It is currently Mon May 04, 2026 10:23 am
 Post subject: rod ends
PostPosted: Sun Jan 30, 2011 6:41 pm
Is anyone running hiems for tie rod ends on a stock vw steering box pitman arm or is the end of the pitman arm to small for both ends to bolt to it
 Post subject: Re: rod ends
PostPosted: Sun Jan 30, 2011 7:24 pm
I have.. I ran 3/4 hiems and used high misaligned inserts which drop down to 1/2"..
I buy all my stuff here http://www.qscomponents.com/
PostPosted: Sat Feb 05, 2011 11:36 pm
I have some 5/8 bore with 3/4 thread that work great for steering.... If your iterested i could fix you up with some heims and make you a couple of misalignment spacer for the steering box
