 Post subject: shock recomendations
PostPosted: Wed Dec 15, 2010 2:54 am
what shocks are you guys with the air bags using?
also if i decide to go with "air" shocks or coilovers which ones are better, fox, king, or racerunner ?
and as far as a shock for when using the factory torsion bars ive heard several say just use cheap "factory" vw shocks :|
 Post subject: Re: shock recomendations
PostPosted: Wed Dec 15, 2010 12:46 pm
I got aftermarket torsion bars, and run a single rancho for like a 10in lift and mine rides like poop. lol so dont go that route! But ill have airbags soon enough
"IT IS WHAT IT IS"
PostPosted: Wed Dec 15, 2010 2:40 pm
How well you set the valving up is probably more important than which of those 3 you set up. Personally I like the Foxes and that's what we run on our buggy - mainly because plenty of people stock cheap spares tbh.
PostPosted: Wed Dec 15, 2010 4:27 pm
The 2.0" race runners are actually bigger than the fox air shocks and can hold a heavier buggy up with less pressure and I think they are a little nicer than the others with some of the "finishing touches". I have fox shocks, King shocks, and Sway-aways (race-runner), and for the money, sway-away is over-all a nicer shock. I have heard people say Fox is the best, but I don't really have anything to complain about with any of them.
PostPosted: Wed Dec 15, 2010 5:01 pm
With Airbags you don't need Coilovers or Air shocks. So your down to an Emulsion shock with or with out a remote resivoir. BTW Factory VW shocks just plain suck and anybody whoes telling you they work fine have probably not ridden in a Buggy with properly valved after market shocks like FOX, King or Sway-a-Way :roll:
PostPosted: Wed Dec 15, 2010 6:56 pm
Cant miss what you never had :lol:
PostPosted: Wed Dec 15, 2010 9:00 pm
that was mostly the one seater guys and is whats on my one seater but they may not work as well on a 2 seater :?
i cant say either way as all i have ever run is stock torsions with rancho 9000's or them old style "bootlegger/whiskey runner/moonshiner" air shocks :lol:
however on this new build im going to try something different and if i dont like it i can always put the torsion bars in :|
PostPosted: Wed Dec 15, 2010 9:04 pm
this may be a stupid question but is the valving and "serviceable" parts somewhat interchangeable or brand specific between the " big 3 " ( fox, king, racerunner ) :?:
PostPosted: Thu Dec 16, 2010 10:59 am
I wouldn't think any are interchangable between brands, but that stuff is very cheap. I rebuilt my fox coil-overs (replaced o-rings, bands, seals, shims, and oil for about $20.
PostPosted: Thu Dec 16, 2010 11:04 am
The only Shims I am aware are interchangable are King and FOA as FOA uses King Shims. The rest of the parts are not as they all build their shocks differently.
PostPosted: Thu Dec 16, 2010 3:30 pm
so will i need to find a dealer around here to get what ever brand i go with revalved/serviced if needed?
if so that will probably decide which ones i go with :|
PostPosted: Thu Dec 16, 2010 4:37 pm
The hardest part about valving and service is buying the Nitrogen setup to refill the shocks afterward. Contrary to pouplar belief they are simple devices to work on. It becomes self evident once you pull one apart.
Here is a link to a guy rebuilding one:
http://dezertdimes.com/2008/12/fox-20-shock-rebuild/
PostPosted: Thu Jun 23, 2011 2:50 am
okay the air bags are out (too much fab work for me), now i got to figure what lengths for the front and rear and either air or coil over
i found this place that seems to have pretty decent prices on the top 3 shocks
http://www.offroadwarehouse.com/products/sfID1/12
for the rear (2x3 or 3x3 arms and maybe with factory tosion bars installed "loose" for backup)
im thinking about 12 or 14 in. racerunner 2.0 air shock or fox 2.0 coilover
http://www.offroadwarehouse.com/product ... /sfID3/684
http://www.offroadwarehouse.com/product ... 3/sfID3/97
or maybe the 2.0 fox air/coil over
http://www.offroadwarehouse.com/product ... /sfID3/104
for the front i got a few different combinations i can go with
stock torsion plates with emulsion shocks or thru rods with air or coil over shocks
beams - stock beam or warrior beam w/8 in. towers or aluminum beam w/towers
trailing arms - stock arms or extended arms w/ stock shock mount or extended arms w/ shock mount relocted further back
by the way ive got 2 projects going (slowly) one is my new beeline cobra for woods riding/hillclimbing and the other is my old fugitve im fixing up (make perty and light) to ridge run and drag race, also to be driven on the street occasionaly on nice days
PostPosted: Thu Jun 23, 2011 9:07 am
From what I've done I would say 12" is all you really need for the back and 10" is all you need for the front. You can go 14" on the back, but it would be over-kill. My race buggy has 12" coil-overs in the back and has no problem getting 20" of wheel travel and 10" coil-overs in the front and gets around 18" of travel. But then again theres always more than one way to skin a cat :shock:
PostPosted: Thu Jun 23, 2011 3:05 pm
thanks for the input racebug
i think i will probably go with the warrior beam and extended arms on the cobra/woodsbuggy and the aluminum beam and stock arms on the fugitive street/ridge runner buggy with either torsion plates and emulsion shocks or thru rods and air shocks for the front of each buggy?
and for the rear im thinking air shocks for the street/ridge runner buggy and maybe the fox air/coilover for the woodsbuggy or i could just go air shock with torsions loosely installed or coil over only shock?
PostPosted: Fri Jun 24, 2011 10:41 am
I LOVE the way the front end of the new woods buggy rides with air shocks, couldn't be any better! If your going the air shock way in the rear of a buggy, you nmight want to consider 2.5" shocks, or like you said torsion bars loose may do the trick as long as they dont make it too stiff as the arms cycle.
PostPosted: Sat Jun 25, 2011 2:05 am
what do you think about the 2.0 air/coilover for the rear ?
2.0 coil over/air shock $292.50
2.5 air shock $360
http://www.offroadwarehouse.com/product ... /sfID3/105
or just go with racerunner 2.0 air shock for the rear $277.83
PostPosted: Mon Jun 27, 2011 2:32 pm
i've never messed around with the air/coil over shock, but if they are like an air shock you can put coils on, I think they would work fine, but why not just get a coil-over if your going to buy coils anyway? the down fall of the air shock is the duty cycle. They heat up and fade quicker than a emulsion shock. Woods riding shouldnt be too big an issue for an air shock, but if you have plans to do anything faster than normal, it might be worth it to go coil over. but thats just my opinion
PostPosted: Mon Jun 27, 2011 4:41 pm
^^That's why they do a coilover version, so you get the tunability of the air-shock but can take some of the load off it with a light coil spring. That way you just use the air shock as a really long progressive bumpstop.
