It is currently Mon May 04, 2026 7:44 pm
 Post subject: fOX AIR SHOCKS ON FRONT
PostPosted: Mon Dec 13, 2010 9:58 pm
i KNOW THIS IS PROB A STUPID QUESTION???.....WILL JUST FOX AIR SHOCKS AND THROUGH RODS WORK ON THE FRONT OF A LIGHT SINGLE SEATER?..OR WILL I NEED COIL SPRINGS?
PostPosted: Mon Dec 13, 2010 10:00 pm
Works real well, no springs.
PostPosted: Mon Dec 13, 2010 10:32 pm
Thanks Mike.. got several folks tellin me no way!....I think it should ride like a dream!
PostPosted: Mon Dec 13, 2010 11:17 pm
2'' body 10'' travel for front . 2'' x 12'' air shox will work good on back with no problem and great ride. take torsions out or back them off, i know people who run them both ways and been running them for a few years with no problem.
PostPosted: Tue Dec 14, 2010 10:50 am
Finist impression of not working I can find
PostPosted: Tue Dec 14, 2010 11:17 am
Thanks Mike...Im wanting to put a pair on the front of a funco single seater like yours!..Should be the Sheet!
PostPosted: Tue Dec 14, 2010 9:22 pm
I have them on a 4 seater... work great.
PostPosted: Wed Dec 15, 2010 2:35 am
can you use these "air" shocks with a warrior beam and 8" towers or do you have to make seperate mounts back on the frame like in all the above pics?
PostPosted: Wed Dec 15, 2010 9:32 pm
You don't need to have frame mounted shock towers. I'm not sure what stroke shock with 8" warrior beam but shouldn't have any probs. The size of an air shock is the same as any other shock (excluding the shaft).
PostPosted: Wed Dec 15, 2010 9:54 pm
He said SHAFT!
PostPosted: Mon Aug 22, 2011 11:59 am
i was wondering what pressure you guys are running on the front air shocks? i am doing a build right now and just trying to figure it out.
thanks
brian
PostPosted: Mon Aug 22, 2011 12:42 pm
I run around 200-225 psi on my race runner air shocks.
PostPosted: Mon Aug 22, 2011 1:20 pm
I run 160 psi in mine. I think it all depends on shock location and weight of the frot end. If I remember correctly plumberbill runs 420 psi in his.
PostPosted: Mon Aug 22, 2011 2:50 pm
Well thats because he is driving a Tank! :roll: :mrgreen: Hell I would have to go to the 2 1/2" air shocks on mine and run 500PSI and still may need some help. My front end weighs in at around 800#
PostPosted: Mon Aug 22, 2011 6:56 pm
There are so many combinations depending on how you want the car to ride it's all really down to preference, a relatively low pressure (150-200) with a high oil level would give a nice, plush, progressive spring rate, which is probably well suited for most of you guys.
Higher speed stuff would need more gas pressure and less oil, at the expense of ride comfort.
PostPosted: Wed Aug 24, 2011 3:20 am
:shock: :shock: :shock:
PostPosted: Wed Aug 24, 2011 8:38 am
And the pot calling the kettle black. Their front ends weigh as much as my whole car will with me in it
PostPosted: Wed Aug 24, 2011 12:25 pm
Well it's your front beam that turned it into a Tank! :roll:
PostPosted: Wed Aug 24, 2011 3:57 pm
Almost pissed myself with that one. You got a milspec beam to support the tank-like structure that was bending the commercially available beams like they were made of exhaust tubing. My beam made it into a tank :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
