| CV joint degrees. http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=108 |
| Author: | D. Marks [ Sun Mar 11, 2007 8:19 pm ] |
| Post subject: | CV joint degrees. |
I am trying to figure out how to mount my shocks. I have removed the torsion bars and am going to use coilover shocks only. I need to know what angle I can run my cv's at. I have bus cv's. Dean |
| Author: | DVS1 [ Sun Mar 11, 2007 9:42 pm ] |
| Post subject: | |
Check this out. http://www.blindchickenracing.com/How_t ... ts_101.htm |
| Author: | FlaBaja [ Sun Mar 11, 2007 9:45 pm ] |
| Post subject: | |
Dont forget that for every inch of off-set between the trans drive flange and the stub axle at full droop you lose half a degree of angle from those numbers |
| Author: | D. Marks [ Mon Mar 12, 2007 7:35 am ] |
| Post subject: | |
So you are saying that since I.m 3" back I should be at no more than 15.5 degrees? Thanks for the link Dave |
| Author: | Roy [ Mon Mar 12, 2007 5:30 pm ] |
| Post subject: | |
[quote='D. Marks']So you are saying that since I.m 3" back I should be at no more than 15.5 degrees? Thanks for the link Dave[/quote] That is close to correct. If you had your CV's race prepped and clearanced, you could go more. Do you have chromoly cages in them? If you run things on the conservative side, you will not break stuff. Roy |
| Author: | D. Marks [ Mon Mar 12, 2007 7:21 pm ] |
| Post subject: | |
I do have the good ones. I set it up so that it will be no more than 17 degrees extended. Lookes like about 9" of wheel travel. I could get more but I would have to change part of my frame. We'll see how this works. Dean |
