It is currently Sun May 03, 2026 6:19 pm
 Post subject: axel prep?
PostPosted: Thu Nov 11, 2010 4:36 am
Doing a trans change as the first one did n't have enough reverse left to it and it went quick. Changing cross shafts over, nose cone and bearing plate, also CV bells. Anyways, center of seals are punched out from the axel. Maybe I did n't grease the splines well enough or axel ends are n't profiled. Length should be right, (recomended by dealer) 19" or 19.25". 5 rib trans, 3X3 arms, Empi 930 race prep CVs, axels are Latest Rage. I dought that there has been 10 hrs use yet. Next I'll clean the CVs for inspection. Any thoughts, thanks, Dave W.
 Post subject: Re: axel prep?
PostPosted: Fri Nov 12, 2010 9:49 am
Thats normal, just use a glob of silicone! works everytime for me!
