| What valving for Fox Shocks? http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=10335 |
| Author: | kvw [ Tue Sep 21, 2010 10:16 pm ] |
| Post subject: | What valving for Fox Shocks? |
I just got a pair of fox 12" travel shocksfor the rear of my woodsbuggy. I have a 4 seat Warrior chassis on 100" wheelbase we mainly ride at Haspin Acres, trails and climbing hills. I want to know what valving I should run(it currently has (30/70 valving) and also how much pressure should I be running(they currently need charged with nitrogen)? Thanks Kenric |
| Author: | Rick [ Wed Sep 22, 2010 8:06 am ] |
| Post subject: | Re: What valving for Fox Shocks? |
call michael, at offroad-engineering he will tell you every thing you need to know. 619-298-4455 www.offroad-engineering.com/fox-shocks |
| Author: | Odyknuck [ Wed Sep 22, 2010 1:50 pm ] |
You need to know the weight of the rear of the buggy and what arms you are using to determine A) what springs to use. and B) what the valving will be based on what springs you use. The Valving works against the selected spring rate. |
| Author: | trailrider [ Wed Sep 22, 2010 5:01 pm ] |
Are they air shocks or coil over. if they are air shocks are you going to run them with a torsion or no torsion. how much does the rear of the buggy weight. where about are you located. We ride at haspin and i am running sway a way air shocks on my buggy with no torsions and I have not had any trouble with mine. i can try and help you get it adjusted if you want. |
| Author: | kvw [ Wed Sep 22, 2010 10:59 pm ] |
I am located in Monroe Indiana, about 20 miles south of Ft Wayne. The shocks do not have any springs. My rear arms are stock length and I am running torsion bars. I need to check my rear weight. Thanks Kenric |
| Author: | RaceBugg1098 [ Thu Sep 23, 2010 8:33 am ] |
I like my 60/40 valving, and around 200lbs of nitrogen. |
| Author: | Odyknuck [ Thu Sep 23, 2010 9:32 am ] |
Ah! I assumed you had coil overs, my bad! |
| Author: | afterburnt [ Thu Sep 23, 2010 2:57 pm ] |
RaceBugg1098 wrote: I like my 60/40 valving, and around 200lbs of nitrogen. 200 lb of nitrogen are you still using torsion bars
| Author: | Rick [ Thu Sep 23, 2010 3:28 pm ] |
afterburnt wrote: RaceBugg1098 wrote: I like my 60/40 valving, and around 200lbs of nitrogen. 200 lb of nitrogen are you still using torsion barsmines 200psi of nitrogen no tortion, but is coilover. im sure thats what ody has as well |
| Author: | RaceBugg1098 [ Thu Sep 23, 2010 3:48 pm ] |
i thought we were talking about coil-overs too! |
