PostPosted: Mon Aug 23, 2010 12:22 am
i know 3x3 arms are 3 wider and 3 longer and use a 19 1/4 length axle and that 2x3 arms use a stock bus length axle of 18 3/4 but are they 2 back and 3 wide or 3 back and 2 wide?
PostPosted: Mon Aug 23, 2010 12:55 am
2 wider 3 longer
PostPosted: Mon Aug 23, 2010 1:14 am
pipedope wrote:
2 wider 3 longer
thanks for clearing that up for me pipedope
PostPosted: Mon Aug 23, 2010 3:22 am
The more travel you can get, the better. Only had mine running for a few weeks. Lots of quirks to work out and other things to finnish. But, guy's with bad backs were n't sure about having a ride. How ever once they got in and had one, they did n't want to stop and became addicted.
I'm running 3X3's with Empi race prep 930's and FOA 14" dual coil shocks rear. 2 1/2"X1 front trailing arms and 8" travel shock with single 18"coil over spring shock front for 12" travel befor the tie rods hit the frame from top to bottom, (while turned) . Suspension seats, hardly even feel a bump.
Comfortable, fast, and it's a blast! Dave W.
PostPosted: Fri Oct 01, 2010 3:23 am
according to these theirs are 2 longer and 3 wider
http://www.blindchickenracing.com/Produ ... _arms1.htm
PostPosted: Fri Oct 01, 2010 8:33 am
you will be happier with arms 2wider and 3longer
PostPosted: Thu Dec 02, 2010 5:00 pm
this is confusing the hell out of me :? :roll:
bee line list theirs as 2" wider x 3" longer
http://www.beelinechassis.com/Extreme.html
and
blind chicken racing list theirs as 2" longer x 3" wider
PostPosted: Thu Dec 02, 2010 8:09 pm
avery arms will make them any way you want them :wink: for my new build im going with 2 wider and 4 longer :D
lets just ride
PostPosted: Thu Dec 02, 2010 9:56 pm
I'm building a set right now, 4 wider 5 longer.
PostPosted: Thu Dec 02, 2010 10:04 pm
madmike i wish i had half your skill, are you interested in arm request from the public :wink: ? :wink: ? paid half in advance ofcourse?????
lets just ride
PostPosted: Thu Dec 02, 2010 10:49 pm
It really depends on how they are built. Normally the first number is the width and the second is the length. I run a 3x2 Mine are 3 inches wider and 2 inches back. It is harder to get a soft ride out of my set up but by only going back 2 inches it takes alot of angle out of my cv joints, thats how i get away with running stock bus joints and never break them. I will shell a tranny before a joint breaks. Ive broke about 10 trannys ans only 1 cv, it sucks it works that way but I deal with it. :D
PostPosted: Thu Dec 02, 2010 11:53 pm
Hi Kevin . I finally got a chance to break into that Passat trans I busted a while back.The welds came apart on the welded up diff.Are you n Ron coming out Sat?
PostPosted: Thu Dec 02, 2010 11:58 pm
A side shift trans is a little longer so don't forget to factor that in to help.
PostPosted: Fri Dec 10, 2010 8:55 pm
That would have been a typo. The arms are Wider by Longer. Info is fixed now.
Mark
Mark "Crash" Johnson
Blind Chicken Racing
PostPosted: Sat Dec 11, 2010 2:21 am
Mark
thanks for clearing that up :D
