| power steering http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=10067 |
| Author: | bamarx88 [ Thu Aug 12, 2010 7:37 pm ] |
| Post subject: | power steering |
CHAR LYNN TORQUE GENERATOR has anyone used this and did they like it this is for an on and off road buggy i was going to use stock subaru power steering pump |
| Author: | Odyknuck [ Fri Aug 13, 2010 11:01 am ] |
| Post subject: | Re: power steering |
Some like them some don't. I have heard they are very twitchy on hardtop roads. Also they put all the torque thru you steering rack and the "U" joints on the steering shaft unless you direct connect to the rack. I use a ram and servo style and like that concept much better. |
| Author: | Firebug [ Fri Aug 13, 2010 12:32 pm ] |
I like mine but only after I modified the pump. Now I like it very much. |
| Author: | RaceBugg1098 [ Fri Aug 13, 2010 12:56 pm ] |
I love my charlyne set up! I'm also using a subaru powersteering pump |
| Author: | Odyknuck [ Fri Aug 13, 2010 1:02 pm ] |
Firebug wrote: I like mine but only after I modified the pump. Now I like it very much. What did you modify on the pump. Curious minds want to know. |
| Author: | Firebug [ Fri Aug 13, 2010 2:27 pm ] |
Odyknuck wrote: Firebug wrote: I like mine but only after I modified the pump. Now I like it very much. What did you modify on the pump. Curious minds want to know. I did a combination of things to my Subaru pump. and not sure exactly what worked because at the end I removed a burr that could have been causing misreads. I took the pressure side hose off and removed a bigger nut that holds in a spring and BB. It is in a valve and hard to pull out but a needle nose plyer worked. It comes apart but I put a burr on it trying to get it apart. I drilled out the port behind the BB a little bigger,,,replaced the spring with a weaker one ( actually remove a coil also ) and found a smaller BB. All this or part of this led to a much better pressure. Before it was like I had no pump at all. |
| Author: | RaceBugg1098 [ Fri Aug 13, 2010 3:24 pm ] |
I also had to do a little port and polish work to my suby pump |
| Author: | bamarx88 [ Fri Aug 13, 2010 8:00 pm ] |
"I love my charlyne set up! I'm also using a subaru powersteering pump" Do you like it on the road to and what is your rack ratio |
| Author: | RaceBugg1098 [ Mon Aug 16, 2010 8:25 am ] |
mines not bad on the road! my rack is a 1.5:1 |
