It is currently Mon May 04, 2026 12:50 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: my new front end
PostPosted: Thu Jun 04, 2009 8:28 am
What did you do with the valving in the shocks. The Air shocks also have valving that when combined with the Emulsions typically would give you a stiff supension. You would need to make the valving lighter to compensate at least in theory anyways. I have been continplating your method for awhile however your the first I have actully seen do it.
afterburnt wrote:
the fox air shocks are amazing. I have 12 inch shocks on the back and 10 inch on the front. when i figured the backs out, i figured i needed 10 inches of travel, so i bought a 12 inch shock, i wish i would have bought a little longer shock to try and see if i could run a little less pressure, because right now i have the backs at 400 pounds psi. the neatest thing about them shocks, is when you make a jump it feels like your landing on a pillow. i have limiting straps and bump stops on the back, a couple of weeks ago, i looked at the bump stops and believe it or not i never hit them, because when you jump and land, the shocks actually build pressure inside to absorb the rebound. when i run down trails, i could watch my tires move all over the place and the frame runs straight and smooth. its pretty awesome. i ran the back nitrogen shocks for about a year before i put the emulsion shocks on, and that made it even more smoother. you might want to try and leave the torsion in and set it real light to try and help out a little bit, like i said, im running 400 pounds of pressure and the shocks max out at 550. we are going out to wellsville this weekend. if you come out, i could give you a ride around and you could feel for yourself how nice the shocks are.
dave
PostPosted: Thu Sep 24, 2009 8:55 pm
Odyknuck wrote:
Nice job on the rear too. Not to hijack the thread (well maybe so lol) I noticed you are using air and a emulsion shocks with out torsions. How is it working out for you? How much pressure are you running in the airs to get you to preload. My torsions are sacked out and I am considering going this route. I may or may not leave the torsions in.
afterburnt wrote:
thanks for all of the good coments. i guess it was worth being out in the garage everynight until midnight for months. when i do a project like this, i do alot of research on the internet, and i always end up just walking around the junk yard, looking at what i could use. You'd be surprised with what you find, if you have alittle bit of imagination,
thanks again, dave
SubySteve wrote:
Nice work! I like the use of late model everyday parts, I dont think those bearings will ever wear out.
if you like what i did with my front end, you would love my back end. :lol: i took and made new 3x3 trailing arms with microstubs. what i used for that was, the front hubs off of a 1992 chevy 4 wheel drive pickup. i took the truck axles and busted the cv out of it, so i had a stub with a cup on it. i put the stub in the lathe and cut it down, and drilled and tapped the holes so i could bolt a bus cv on it. oh ya, when i was cutting the stub, the material was like case hardend, so i had to use ceramic tooling inserts. but once i got through the hardness, it was pretty soft so i was able to use high speed tap and drill for the holes. the tubing i used for the trailing arms was 1 1/4" x 0.180 wall dom tubing. i was able to use the front rotors off of the chevy truck, but i had to turn them down so they were 7/8" thick because i used wilwood calipers. the best part about this was when i went to the junk yard, they charged me 40 bucks for that whole spindle and axle. heres some pictures of it.
Odyknuck did you convert over to air shocks and if so did you leave your torsion bars in
Afterburnt that is truly awesome !
