It is currently Sun May 03, 2026 5:12 pm
PostPosted: Tue Jun 08, 2010 2:28 am
is it just that old bolt that goes thru there? i cant get the damn thang out
Brandon
PostPosted: Tue Jun 08, 2010 2:48 am
yea its just the big bolt if its loose but still ont slide out i have had them stuck in the bushings from just being in so long
PostPosted: Tue Jun 08, 2010 12:00 pm
be sure you take the spring plate off first, or you could be in for a little suprise :mrgreen:
PostPosted: Tue Jun 08, 2010 7:52 pm
Yea, either take the spring plate all the way off, ( if you plan on re-setting the torsion) or take all the bolts out of the spring plate that go through the arm. Slide the arm out of the spring plate, take the pivot bolt out, (that big allen head bolt) And you'll have to do quite a bit of wigglin' to get 'er off.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Tue Jun 08, 2010 8:01 pm
There is nothing fun about removing frozen Pivot Bolt... Make sure you follow KoKo's advice and remove as much tension as possible. I would also spray the crap out of the bolt with liquid wrench or something else. If you strip the torsion housing, it is a pain and the butt to fix.
PostPosted: Tue Jun 08, 2010 10:15 pm
I had a pivot bolt froze up in the bushing and could not get it out so i sprayed it with some PB blaster and then had to take a air hammer with a punch in it and hammer on the center of the hex head to brake the rust loose .
PostPosted: Tue Jun 08, 2010 10:55 pm
Most important. Put something under the vehicle (old wheels etc, other than a jack stand) before you heav on it and pull it over on to you.
PostPosted: Tue Jun 08, 2010 11:07 pm
yeah, ive got my old tires and rims under it i got one of my arms out but the other one is being a pain in the ass im still workin on that side
Brandon
PostPosted: Wed Jun 09, 2010 1:04 pm
Keep tryin, they can be a bit%h. I've had 'em stuck so bad I had to cut open a window on inside of it and air hammer the bolt out. :evil:
PostPosted: Thu Jun 10, 2010 3:03 am
alright on the one that i was talkin about that was bein a pain in the ass i got it un-done and its not threaded its like its just settin there ive tryed beatin it out what should i do?
ive heated it put vise grips on it and tryed to yank it out put vise grips on it and try to beat it out i aint gettin nowhere
Brandon
PostPosted: Thu Jun 10, 2010 10:13 am
i had the same problem a while back it was loose but could not get it out and onve i did it was broken here is mine scroll down and you will c and after i fixed it on page 2 just hope this has not happened its terrible
http://www.woodsbuggy.com/index.php?opt ... f=5&t=3204
PostPosted: Thu Jul 01, 2010 7:37 am
i ended up cuttin the bolt out with my welder so now i need that big allen head bolt does anyone know where i can get one?
Brandon
PostPosted: Thu Jul 01, 2010 7:53 am
Any vw shop. Whoever is close to you..
PostPosted: Thu Jul 01, 2010 10:58 am
I've got new ones that have a hex head on them that take a regular wrench.
I've got used ones that take the allen wrench.
If you can't find one close, PM me and I can send you one out.
