It is currently Tue May 05, 2026 1:39 am
 Post subject: Front bump stops
PostPosted: Fri Sep 25, 2009 11:57 am
I have a 6" wider warrior beam with 8" towers. Do most people run urethane bump stops, or just let the arm hit the built in metal one?
 Post subject: Re: Front bump stops
PostPosted: Fri Sep 25, 2009 12:54 pm
Good question,,,I have no bump stops but I think the shock absorbs enough before it bottoms ,,or runs out of travel. I am working on a way to put on air bags which are bump stops within themselves.
PostPosted: Fri Sep 25, 2009 1:09 pm
I ran these on my old buggy. You will loose a little travel, but if it bottoms out it’s allot softer.
http://www.energysuspensionparts.com/proddetail.asp?prod=9.9132
PostPosted: Fri Sep 25, 2009 6:08 pm
I just let the arm hit the metal...
