It is currently Mon May 04, 2026 11:30 am
 Post subject: combo spindles
PostPosted: Thu Jun 18, 2009 10:12 pm
Why are they called combo spindles and why do i want them?
 Post subject: Re: combo spindles
PostPosted: Fri Jun 19, 2009 7:51 am
Because when you buy them and the wife sees the price you will get a combo "emergency protective order/divorce papers". Why would you want them? Because it is cheaper to get a hooker once a week than to have a wife.
Aut Viam Invenium Aut Faciam!
PostPosted: Fri Jun 19, 2009 7:52 am
guess its time to go buy a set then
PostPosted: Fri Jun 19, 2009 9:23 am
They are called Combo Spindels because the King pin also is the Link Pin mount in one package. The Combo spindel Typicaly uses an 1 1/2" king pin were the VW setup is only 19mm (dont remember exactly). There is quite a difference in strengh and Bushing (or roller bearing) contact surface to decreace the time between rebuilds. Hands down a beetter Mouse trap. If I was to do it over I would have bought Fodril Combo spindels with the roller bearing instead of the Tweeds design with Bronze alloy bushings.
PostPosted: Fri Jun 19, 2009 6:40 pm
thanks. that means there no using existing brakes obviously. Mairage is for crazy peaple. But wife or not I do have two kids and a girlfriend and NO money.
PostPosted: Fri Jun 19, 2009 7:03 pm
All the combo spindels that I am aware of use the balljoint brake backing plate pattern. They run larger bearings however you can machine a king pin drum to accept them and use a ball joint backing plate. Ball joint drums do not have enough material to machine out to house the inner bearing.
PostPosted: Fri Jun 19, 2009 10:31 pm
Thanks for all the info.
PostPosted: Mon Jul 20, 2009 12:37 am
I have no experience with them, but as far as rotors or drums went, I don't think it maters. It depends on the bearing kit to make one or the other work, as combo spindles also have a larger spindle diameter to reduce chance of bending or breaking. As far as I know, but that is very little.lol.
