It is currently Mon May 04, 2026 5:22 pm
PostPosted: Fri Mar 28, 2008 9:02 pm
What does everybody torque there axle nots to? I have stock stubs. Thanks Jason.
PostPosted: Fri Mar 28, 2008 10:00 pm
i do not toruq them. just put them tight
PostPosted: Sat Mar 29, 2008 11:39 am
They need to be torqued to atleast 200 ft lbs or they will come loose :eek:I use the one you hit with a hammer and have never had on come loose.
aaron
PostPosted: Sun Mar 30, 2008 12:31 am
275+ you don't want them coming loose or the splines in your hubs will magically dissappear.The nuts on my swingaxle race car are over 500 but that is n aftermarket axle.
PostPosted: Sun Mar 30, 2008 8:45 pm
yea and it took us a 10 foot cheater pipe to get em loose so thats what we used to tighten em back up haha
"Lets go get stupid"
PostPosted: Sun Mar 30, 2008 9:55 pm
pipe dope and an adjustable will hold anything. just ask pipedope himself. lol! sorry brian i had to say that.
kevin
Ridin' in a souped up honda is kinda like ridin' the short bus, no matter were ya go someone is lookin' at ya!
PostPosted: Mon Mar 31, 2008 4:49 pm
I was told if you use the kind ya hit with the hammer it will damage the axle bearings.
I bought this torque multiplier from John at aircooled.net called a torquemeister. You can rent it from John for $15 if you return it within 21 days. I bought one for $65 years ago because it'll loosen and tighten axle nuts and gland nuts on the flywheel (6v & 12v) with little effort. It's a neat looking little tool that you use with your 1/2" torque wrench. It's a 9:1 multiplier meaning you set your torque wrench to 30ft/lbs and it'll tighten the nut to 270ft/lbs.
I think it's worth the money if you do most of the work on your own bug or buggy.
WvvW Life really is an adventure! Covered with bug junk
