It is currently Mon May 04, 2026 5:22 pm
 Post subject: ball joint arms
PostPosted: Wed Mar 05, 2008 11:21 pm
Anyone have the website for the guy in michigan that builds extended ball joint arms?
All that really matters is" How many pounds per horsepower ? "
PostPosted: Thu Mar 06, 2008 5:48 pm
I think this is the guy .
Jim cathcart at 517-543-9649
PostPosted: Thu Mar 06, 2008 6:21 pm
yes thats him
PostPosted: Thu Mar 06, 2008 6:45 pm
Where is he located at in Michigan? I looked everywhere for a set, no luck, but it looks like there is one, thanks for the info. 8)
PostPosted: Thu Mar 06, 2008 7:09 pm
He is in Charlotte Michigan
I think he is a member here also.
PostPosted: Thu Mar 06, 2008 10:31 pm
Thanks
PostPosted: Thu Mar 06, 2008 11:01 pm
What kind of bennafits from running extended arms on front? I have not talked to or rode with anyone who runs them. I am sure you get some ground clearance, but what else?
Mark
That's what I'm talking about!
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Fri Mar 07, 2008 12:02 am
more travel, means softer ride,,softer ride means less rebound. or something :?
PostPosted: Fri Mar 07, 2008 5:29 am
You get a much better ride quality. Once you have tried some, you will never go back.
PostPosted: Fri Mar 07, 2008 8:18 am
Softer ride. Will go over rocks, roots logs better.
PostPosted: Fri Mar 07, 2008 9:56 am
I extended mine 2 1/2 inches. It does make a big difference, imo. It was a real PITA getting them setup correctly, though.
PostPosted: Fri Mar 07, 2008 7:37 pm
Do you run the same amount of springs? I imagine the extended trailling arm would do the same? Wouldn't you have to raise the rear if you extended the arms in the front?
Mark
High speed
Low drag
Teflon coated
PostPosted: Fri Mar 07, 2008 8:33 pm
Not necessarily it could just be set up to have more droop travel in the front. The longer arms will apply more leverage to any spring used wether a torsion spring pack, coil over or nitrogen. If you want to retain the same spring rate as before it will likely need to be stiffened up.
PostPosted: Fri Mar 07, 2008 8:35 pm
There's also a good chance it will be just right...try it out on a ride with some good hills first. :wink:
PostPosted: Sat Mar 08, 2008 8:21 am
The 4 seat I am building is long and heavy- I am looking at future changes to make perform better. I will ride it the way it is for now but thank you guys for all the info!
Mark
High speed
Low drag
Teflon coated
