It is currently Sun May 03, 2026 4:49 am
 Post subject: Austin's Alabama A Arm's
PostPosted: Wed Dec 12, 2012 11:03 pm
Image All from pull a part and the metal store. Rides sturdy soft and lots of ground hieghth.18.5 inches with 16" wheels.Rims from a trunk spare tire.
PostPosted: Thu Dec 13, 2012 9:48 am
I love that's setup. He came down to ride with up and creeped right up the right side of pride rock, only seen 2 Buggys climb it in ab 15yr
PostPosted: Thu Dec 13, 2012 11:32 am
I just love the salvage yard engineering? It may not be sexy but it really works.
PostPosted: Thu Dec 13, 2012 5:19 pm
I think I have seen that buggy before....
I think I can, I think I can....
PostPosted: Thu Dec 13, 2012 7:14 pm
same buggy, just updated.. cedric added the link bar between shocks on this setup and it seems alot lighter than before, works really good 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Fri Dec 14, 2012 11:12 am
Too bad those arms aren't 4x4! That is why I live s-10 chevys. They have lots of a arm travel.
PostPosted: Fri Dec 14, 2012 7:20 pm
watch these a arms in slo mo. They are taking a beating but the frame is floating.The giant ball joints , spindles, wheel bearings, and tie rods are from a 90's rear wheel drive isuzu truck front end(put the lt on the rt and rt on the left so the tie rod will be in back).Mitsubishi Eclipse rear coil springs.90's Cadillic rack and pinion(look for a Cad that has the motor removed and 1 bolt and it's off.Cad is 2" wider than a normal GM .Perfect for this frame's geometry. Tubing inside of larger tubing to make a arm hinges.A very tough and practical set up.Thanks for the good comments.
PostPosted: Sat Dec 15, 2012 12:50 am
it looks good dd and glad its working like you hoped
PostPosted: Tue Nov 12, 2013 8:38 pm
I have the same home made arms and wheels on the Passat and absolutly love em and will not go back to anything else.
PostPosted: Tue Nov 12, 2013 9:13 pm
Reminds me of Junkyard Wars. I think its great and the price seems right too. If I had access to all this great info when I was younger along with the time no telling what I would have created.
PostPosted: Wed Nov 13, 2013 12:27 am
He went to dual webers a few weeks ago so now he's double dangerous.
PostPosted: Wed Nov 13, 2013 10:39 am
I understand that A arms just go up and down and not back at all, but think about it . When you are climbing a rocky hill is your buggy slanted on an incline and so is the terrain? Those 16" 760 tires roll over things easy as well. If you have time, but no money, it's a great way to go. $500 from welding supplies to lug nuts would get you rolling.
PostPosted: Thu Nov 14, 2013 12:48 am
Passatt , any vids of the biscuit with new rubber??????????? Just curious. I haven't seen any vids of the hill climb etc the cd
PostPosted: Thu Nov 14, 2013 2:11 am
PostPosted: Fri Jan 16, 2015 1:14 am
Here's a good winter project!
