It is currently Sun May 03, 2026 4:14 am
PostPosted: Mon Jun 16, 2014 8:30 am
bent the crap out my rear trailing arms over the weekend. not sure the direction i wanna go with new ones. if i go wider its not going to fit on my trailer (without modifications). really dont want to spend a bunch of money if im not "improving" something. dont wanna go longer because my weight bias is to far forwards as it is. i was thinking maybe stock x 1 trailing arms but not sure. whats the chances my present axles will still fit if i go 1" longer? does anyone on here make stock x stock or stock x 1 trailing arms?
PostPosted: Mon Jun 16, 2014 8:47 am
I know a guy that makes braced stock arms. If you want I will try and get pics.....
PostPosted: Mon Jun 16, 2014 9:18 am
yeah i might be interested
PostPosted: Mon Jun 16, 2014 7:42 pm
were you riding near columbus
PostPosted: Mon Jun 16, 2014 10:32 pm
I got a set of stock boxed that came off my buggy when i rebuilt it. There pretty beefy id sell you cheap
PostPosted: Tue Jun 17, 2014 9:19 am
no i was down in tar hollow
PostPosted: Tue Jun 17, 2014 9:21 am
i jumped the gun and ended up ordering these
http://www.mooreparts.com/1451-AC530012-E/
with a little luck i can use the same axles
PostPosted: Tue Jun 17, 2014 11:10 am
You will need regular car axles thing axles may work I can't remember
PostPosted: Tue Jun 17, 2014 1:31 pm
if im running a 3 rib? type 2 cvs?
PostPosted: Tue Jun 17, 2014 2:22 pm
Yes my dad was running them and he was running just a regular old car axle with the Rings for the snap ring still on it
PostPosted: Thu Jun 19, 2014 4:25 pm
moore parts called me today and said they couldnt get the arms i ordered so they asked me if i wanted to upgrade to the heavy duty version for the same price. I asked them why they even called thats a no brainer.
not sure what they mean by heavy duty maybe chromoly instead of mild steel? i guess ill know next week when i get them.
PostPosted: Thu Jul 03, 2014 12:13 am
moved two notches on the outside, and seems a little stiff. wanted to cut the lower stops out but its a straight line up to the lower bolt. does anyone have a pic of one cut and how far to go towards the bolt. its irs bug all stock except shocks.
PostPosted: Thu Jul 03, 2014 11:40 am
i just notched the bottom of the spring plate where it hits the stop. kept grinding it out till it was right.
