It is currently Sun May 03, 2026 5:51 am
PostPosted: Thu Jun 07, 2012 10:08 pm
I never tried to take a set of kingpin spindles off before and I'm having some troubles. I just want to take them off from the front trailing arms. I took the main bolts out of the trailing arms and twisted the ends of the link pin but no luck on knocking them loose.
PostPosted: Thu Jun 07, 2012 11:52 pm
You should be able to knock them out with a hammer. Make sure you take the bolts all the way out and off the arms hit both pins till they start moving there are shims in there make sure you keep them in order.
PostPosted: Fri Jun 08, 2012 8:01 pm
Take a skinny chisel or screw driver to the split where you took those bolts out and widen the gap. Then spray with break free and let em sit for 10 minutes.Then sledgomatic while the chisel is still in there.Propane torch is darn good aswell.
