It is currently Sun May 03, 2026 4:12 am
 Post subject: Alxe stub swap help
PostPosted: Wed Feb 22, 2012 9:56 pm
I run a 6rib with and stock arms and I'm swapping the stubs out for type 4 stubs and type 2 cv. I put it all in the driver side at full drop turns fine and free and the axle moves free. The pass side is very hard to turn and the axle will not side at all but if I jack the arm up about 1" it just as free as the other side the angle is the same on both at full drop and never had a problem before just trying to upgrade. Could this be a bad joint or something else all was used parts. And I think I clocked them right wide on top out on one side and small side top out on the other??? need some help not sure if I'm over looking something or not doing something right.
 Post subject: Re: Alxe stub swap help
PostPosted: Wed Feb 22, 2012 10:41 pm
is the tranny completely sguare? could even be as simple as the camber adjustment from spring plate to arm!
lets just ride
PostPosted: Wed Feb 22, 2012 11:24 pm
I think you have a wo out bearing and the rotor is sliding on the brake pad until the weight is lifted off .
PostPosted: Thu Feb 23, 2012 1:50 am
do this for both sides, take the axles out and jack the trailing arm up till tranny drive flange and the stub axle flange are parallel and measure the distance from flange to flange, im thinking the tranny is offset to one side
PostPosted: Thu Feb 23, 2012 1:58 am
I never would have thought of that.. I would have ended up replacing all the CV joints before I thought to check the brake. Great idea..
PostPosted: Thu Feb 23, 2012 10:21 am
I will look at the bearing but they only have one ride on them
PostPosted: Thu Feb 23, 2012 9:48 pm
Thanks for the help guys it ended up being a cv but I have no idea what wrong with it it locks up in one spot looks fine its something with the outside ring I put a new star and cage it still done it got a new one all is good thanks for everones ideas
