It is currently Sun May 03, 2026 12:53 pm
 Post subject: wheel bearing ?
PostPosted: Mon Jan 16, 2012 11:52 pm
Had a garage argument. What is the orientaion of the rear wheel bearings. Roller bearing on the oustide right?
The other ?
i have a ball joint frontend, and it looks to be all stock but i cant find the right bearings. It has caliper mounts and slimmed down drums. Making me think its a stock disc brake front end, is that possible. I can fit them in the rotor but the inside on the spindle is not fitting. im stumped
 Post subject: Re: wheel bearing ?
PostPosted: Tue Jan 17, 2012 3:47 am
Rear Ball brg inside and 2pc roller outside
PostPosted: Tue Jan 17, 2012 6:10 am
if it is a 67 balljoint front then spindles are one year only and bearing are different size.
