| Buggy weight poll http://woodsbuggy.com/phpBB3/viewtopic.php?f=33&t=7335 |
Page 1 of 3 |
| Author: | Odyknuck [ Tue Aug 04, 2009 12:47 pm ] |
| Post subject: | Buggy weight poll |
Curious on what everybodys Buggy weighs and what the Bias is. Mine weighs in at 2240 pounds with 6 gallons of gas and the spare tire. No driver or passenger. The bias is 31% front and 69% rear. |
| Author: | mudd mutt [ Tue Aug 04, 2009 2:00 pm ] |
| Post subject: | Re: Buggy weight poll |
Wow! I need to look at it again! or weigh mine lol my old 1 with me in it was 1465 I'll see when my buddy has his scales out I'll try to get mine on them,,,I'm curious now |
| Author: | plumberbill [ Tue Aug 04, 2009 3:24 pm ] |
dont know the bias but i just weighed in at 2240lbs with a half a tank of fuel no fiberglass hood, no tools, no beer filled cooler, no riders |
| Author: | nitro_mudder [ Tue Aug 04, 2009 4:43 pm ] |
1630 full tank, no rum, whiskey or shine. Oh, or me either. No clue on bias but I can lift the front off the ground fairly easy. And yes I know I'm working on that |
| Author: | Stevo [ Tue Aug 04, 2009 5:54 pm ] |
Looks like a good place for a disclaimer!!! Woodsbuggy.com does not endorse in any way drinking and driving nor do we recomend it! |
| Author: | MadMike [ Tue Aug 04, 2009 8:30 pm ] |
Last weigh in was full of fuel (10gal) no one in it, all tooled up ready to ride, 1840#. Since then I have changed a bunch as far as bias, no idea what it is now. |
| Author: | Odyknuck [ Wed Aug 05, 2009 3:56 pm ] |
Its also a good place for your Buggys weight. Stick to the plan Man, stick to the plan! SubySteve wrote: Looks like a good place for a disclaimer!!!
| Author: | khaney01 [ Wed Aug 05, 2009 4:29 pm ] |
Mine weighs 1140 with a full 8 gallon tank. |
| Author: | Stevo [ Wed Aug 05, 2009 5:25 pm ] |
Odyknuck wrote: Its also a good place for your Buggys weight. Stick to the plan Man, stick to the plan! SubySteve wrote: Looks like a good place for a disclaimer!!! Woodsbuggy.com does not endorse in any way drinking and driving nor do we recomend it! Sorry never weighed it. |
| Author: | tw9294 [ Wed Aug 05, 2009 10:04 pm ] |
Mine weighs in at 1800 lbs with no in it and aprox 5 gals gas. Not sure on bias but has ft end weigt. Needs two people to pick it up and move it.
| Author: | chris38375 [ Thu Aug 06, 2009 12:22 pm ] |
1250 with nobody in it and 5 gal. of gas |
| Author: | aboone993 [ Thu Aug 06, 2009 6:59 pm ] |
Mine is #460 front #1100 rear empty using the truck scales at work that rounds off to the nearest 10 lbs |
| Author: | Odyknuck [ Fri Aug 07, 2009 8:46 am ] |
Total weight = 1650 # 460 # Front Bias = 29% 1100 # Rear Bias = 71 % Pretty close to my Bias. A little light on the front end. aboone993 wrote: Mine is #460 front #1100 rear empty using the truck scales at work that rounds off to the nearest 10 lbs
| Author: | RaceBugg1098 [ Fri Aug 07, 2009 12:17 pm ] |
My race buggy weighs around 1750 lbs with 12-15 gallons of fuel, me in a firesuit and a helmet on.each rear tire weight was around 600lbs and front was 200lbs each (I know it doesn't add up, it was over a year ago and I don't have the paper in front of me). I think that was close to the dry weight of my old woods buggy |
| Author: | eggman [ Mon Aug 17, 2009 8:32 pm ] |
Mine weighs in about 1840 pounds. Will check the weight bias next time. |
| Author: | nitro_mudder [ Mon Aug 17, 2009 9:00 pm ] |
Any idea where I could check the bias? I used scales at the compost. weigh one end then the other? |
| Author: | chris38375 [ Mon Aug 17, 2009 10:42 pm ] |
try a local guy there that races dirt track some of the big time late model racers have scales |
| Author: | Odyknuck [ Wed Aug 19, 2009 9:18 am ] |
I took mine to the local landscaping outlet. They had a certified scale. Ipulled the front wheels on the scale, then the whole buggy and then just the rear wheels. I also weighed my trailer for plates. The guy charged me 5 bucks, I gave him 10. nitro_mudder wrote: Any idea where I could check the bias? I used scales at the compost. weigh one end then the other?
| Author: | MadMike [ Wed Aug 19, 2009 8:23 pm ] |
Odyknuck wrote: I took mine to the local landscaping outlet. They had a certified scale. Ipulled the front wheels on the scale, then the whole buggy and then just the rear wheels. I also weighed my trailer for plates. The guy charged me 5 bucks, I gave him 10. nitro_mudder wrote: Any idea where I could check the bias? I used scales at the compost. weigh one end then the other? Cheap skate, I tossed a twenty to the old lady at the scrap yard |
| Author: | Odyknuck [ Thu Aug 20, 2009 10:15 am ] |
You think I am cheap! My wife said I should have given him the Five. |
| Author: | plumberbill [ Thu Aug 20, 2009 12:37 pm ] |
cost me 20.00 to weigh the whole buggy |
| Author: | mudd mutt [ Sun Aug 23, 2009 4:18 am ] |
Hey Steve what do you think the bias is on this one! Looks nose heavy to me http://cgi.ebay.com/ebaymotors/2009-V8- ... 06.c0.m245 |
| Author: | Odyknuck [ Mon Aug 24, 2009 12:57 pm ] |
Yea that is definatly nose heavy. Probably a 60 front 40 rear Bias. Great in the sand until you decide to go airborn, better be at full throttle on take off. mudd mutt wrote: Hey Steve what do you think the bias is on this one! Looks nose heavy to me
| Author: | ridenrace6 [ Sun Nov 08, 2009 3:02 pm ] |
no driver 1480lb total 431lb front 1049lb rear 70.8% rear bias (rear traction or bite) 29.2% front bias with me in it 1777lb total 527lb front 1250lb rear 70.3% rear bias (rear traction or bite) 29.7% front bias |
| Author: | Terry fryer [ Sat Dec 19, 2009 6:59 pm ] |
I am curius to what a ky single seater's bias is. I am considering putting the ecotec in one if I can get the weight ratio close. Or is that a big secret? |
| Page 1 of 3 | All times are UTC - 5 hours [ DST ] |
