Board index » General » Safety
 Post subject: Rollbar Padding ??
PostPosted: Wed Oct 21, 2009 7:45 pm
So whats the common practice on attaching this stuff? Leaning towards Colored Duct tape. Let me know if you got better ideas. Not that mines hard to beat. :mrgreen:
 Post subject: Re: Rollbar Padding ??
PostPosted: Wed Oct 21, 2009 8:34 pm
tyraps and duct tape (the thin stuff) works good for me. i usually snip the tyrap then heat up a screwdriver tip and melt the stub then apply the tape.
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Oct 21, 2009 9:05 pm
Zip-tie it but turn the zip-tie around backwards, pull tight , add cut off excess. the sharp end will asorb into the pad and then it won't cut you. or tell the tool truck to order you some flush cuts and they trim really close and the end won't cut you. That's my .02 :D :D :D
PostPosted: Wed Oct 21, 2009 9:35 pm
Slick idea, that's a keeper.
PostPosted: Thu Oct 22, 2009 8:07 am
zipp tie but also use them on the in side of the pad. on the bar pull it tight cut it diagonally with about a 1/4 inch sticking up. keeps the pad from spinning. :D
PostPosted: Thu Oct 22, 2009 9:02 am
I use electrical tape and it works fine. The padding does not move. I see no need for Tie wraps.
PostPosted: Fri Oct 23, 2009 12:03 pm
Go to a fabric store and pick up some vinyl in the color you like. Measure the circumference of your padding and add the circumference of the tube plus one inch. Cut the vinyl to this width. Fold the vinyl in half length wise with the unfinished side out. Sew a seam ½ inch from the edge to form a tube. Cut the length 12 inches longer than the padding. Turn the tube of vinyl color side out and slide it over your padding leaving 6 inches of vinyl on each end of the padding, tuck the extra 6 inches on both ends into the end of the padding (make sure the length seam gets tucked into the inside of the padding where the roll bar goes.) Put it on the roll bar and secure with a couple of zip ties. These covers will last for years and protect the padding, also helps keep you’re a$$ from getting wet climbing over a soggy pad.
PostPosted: Fri Oct 23, 2009 12:21 pm
This has always worked great for me. Every once in a while, I will even run a "New" layer of tape just to give it a clean look.
PostPosted: Fri Oct 23, 2009 2:48 pm
Yea they do need a new layer from time to time. There are some Wellsville trails that have a lot of Brior that rip the tape.
PostPosted: Sun Nov 15, 2009 12:11 am
i think i got about 30 rolls or so on mine by now -- good thing it dont weigh much!!!!!!!!!!! :lol:
PostPosted: Tue Nov 17, 2009 5:17 am
zip ties work good, but then again i use them for everything
Brandon
